Your ideal temperature any time of day.
- Controls the room temperature by a time control depending on your individual daily routine. It provides flexibility for programming each day of the week.
- Holiday mode for maximum energy saving.
- Fits most current radiators. Simply replace conventional radiator thermostats.
- Ready to use in no time: can be installed easily, without special tools or expertise.
- Manual temperature control at the thermostat, and intuitive operation via an app for smartphone, tablet and computer.
- Illuminated display to show temperature.
- Individually expandable at any time with other devolo Home Control components.
- Future-proofed thanks to standardised Z-Wave® wireless technology.
- 3-year manufacturer's warranty.
The devolo Radiator Thermostat ensures your personal and individual temperature at the right time and in the right room. Thanks to the time control that can be individually programmed for each day of the week, your bathroom, kitchen or living room will always be the correct temperature when you are there. The radiator can automatically turn down when you're not home. That's how smart energy saving is today!
The devolo Radiator Thermostat can be installed in no time, without any special tools or expertise. Your conventional Radiator Control can be replaced in under a minute. You can, of course, set the new thermostats also manually, if necessary. Using an app, you have access to your room temperature at any time, even at a distance and can warm up your house on your way home, for example.
devolo makes it easy - making your home into a smart home
The requirements for a modern home have grown. For years, the focus has been on a stable and secure connection for computers and state-of-the-art consumer electronics. Now users are seeking more control over their home, a concept called the "smart home" for short. Existing systems were not particularly attractive for most people. Exceedingly high prices, generally over-complicated operation, time-consuming and expensive installation as well as isolated solutions for each area have left the dreams of a smart home unfulfilled. The world market leader in Powerline home networks is developing devolo Home Control as the first simple home automation solution. -
Easy to retrofit, easy to operate and easy to expand
devolo Home Control offers the core attributes that users are familiar with from the world of dLAN adapters: Easy to retrofit, easy to operate and easy to expand. It is an entirely new solution that encompasses all of the key areas for smart homes. Thanks to its modular design, it can also be tailored to each individual home. This allows devolo Home Control to grow to meet the tasks to hand; it can even be installed piece by piece or modified as needed. -
Basic needs for safety, security, comfort, convenience and energy savings as driving forces
devolo's focus on the basic needs of safety, security, comfort and convenience covers the essential requirements for a smart home. In times of rising energy costs, efficient utilization of energy is an important factor. devolo Home Control harmonizes all of these needs and offers a simple, integrated solution. devolo Home Control will be developed as an independent product portfolio alongside its line of dLAN Powerline adapters. As with its Powerline solutions, the company is building on open architecture based on international standards for Home Control as well.
- devolo Home Control Radiator Thermostat - radiator thermostat - Z-Wave
- Product Type
- Radiator thermostat
- Connectivity
- Wireless - Z-Wave
- Frequency Band
- 868.42 MHz
- Display
- LCD
- Localisation
- United Kingdom
- 3-year warranty
- 5.1 cm x 9.1 cm x 5.1 cm
- Product Type
- Connectivity Technology
- Wireless - Z-Wave
- Max Range Indoors
- 20 m
- Frequency Band
- 868.42 MHz
- OS Required
- Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple OS X 10.9 Mavericks, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
- Display
- LCD
- Temperature Range
- 4 - 28 °C
Thermostat
- Backlit display
- Form Factor
- AA type
- Required Qty
- 2
- Included Accessories
- 2 AA batteries
- Localisation
- United Kingdom
- Warranty
- 3-year warranty
- IP20
- 5.1 cm
- 9.1 cm
- 5.1 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
