Devolo Home Control Door/Window Contact
Quicklinx: BQYWWS00 Mfr#: 9501
Your personal bouncer!
  • Detects open doors, windows or drawers without fail and sends text*, e-mail or app notifications.
  • Versatile installation via adhesive film or screws (included in box contents).
  • Continuous brightness and temperature measurement, e.g. as feedback to the light and radiator control.
  • Intuitive operation by browser, and a free app for smartphones and tablets.
  • Unobtrusive design for inconspicuous placement.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to innovative Z-Wave® wireless technology.
  • 3-year manufacturer's warranty.
*devolo provides you with 15 free SMS messages. For additional notifications, you can purchase a devolo Home Control SMS pack.
The devolo Door/Window Contact gives you versatility when installing it and can be placed discreetly in your smart home. It is reliable in detecting open doors, windows, or drawers and sounds the alarm via text and e-mail if something isn't as it should be. Furthermore, it works hand-in-hand with a series of additional Home Control components. If the window in a room is open, for example, the smart radiator could switch off automatically. The integrated brightness and temperature sensors of the devolo Door/Window Contact can also be the signal generators for the light controls.
  • devolo makes it easy - making your home into a smart home
    The requirements for a modern home have grown. For years, the focus has been on a stable and secure connection for computers and state-of-the-art consumer electronics. Now users are seeking more control over their home, a concept called the "smart home" for short. Existing systems were not particularly attractive for most people. Exceedingly high prices, generally over-complicated operation, time-consuming and expensive installation as well as isolated solutions for each area have left the dreams of a smart home unfulfilled. The world market leader in Powerline home networks is developing devolo Home Control as the first simple home automation solution.
  • Easy to retrofit, easy to operate and easy to expand
    devolo Home Control offers the core attributes that users are familiar with from the world of dLAN adapters: Easy to retrofit, easy to operate and easy to expand. It is an entirely new solution that encompasses all of the key areas for smart homes. Thanks to its modular design, it can also be tailored to each individual home. This allows devolo Home Control to grow to meet the tasks to hand; it can even be installed piece by piece or modified as needed.
  • Basic needs for safety, security, comfort, convenience and energy savings as driving forces
    devolo's focus on the basic needs of safety, security, comfort and convenience covers the essential requirements for a smart home. In times of rising energy costs, efficient utilization of energy is an important factor. devolo Home Control harmonizes all of these needs and offers a simple, integrated solution. devolo Home Control will be developed as an independent product portfolio alongside its line of dLAN Powerline adapters. As with its Powerline solutions, the company is building on open architecture based on international standards for Home Control as well.
devolo Home Control Door / Window Contact - multipurpose sensor - Z-Wave
Multipurpose sensor
Sensor Type
Temperature, ambient light, door and window
Wireless - Z-Wave
Frequency Band
868.42 MHz
United Kingdom
3-year warranty
2.8 cm x 2.3 cm x 9.6 cm
Multipurpose sensor
Sensor Type
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple OS X 10.9 Mavericks, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
Motion Sensor
Detection Range
10 m
CR123A
CR123A lithium battery
United Kingdom
Warranty
3-year warranty
2.8 cm
2.3 cm
9.6 cm
-10 °C
10 - 85% (non-condensing)
