Your basket is empty
Devolo Home Control Door/Window Contact
Quicklinx: BQYWWS00 Mfr#: 9501
Type: Multipurpose sensor
6 in stock
£33.33 ex VAT
£39.99 inc VAT
Standard delivery Delivered within 3-5 working days
Your personal bouncer!
  • Detects open doors, windows or drawers without fail and sends text*, e-mail or app notifications.
  • Versatile installation via adhesive film or screws (included in box contents).
  • Continuous brightness and temperature measurement, e.g. as feedback to the light and radiator control.
  • Intuitive operation by browser, and a free app for smartphones and tablets.
  • Unobtrusive design for inconspicuous placement.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to innovative Z-Wave┬« wireless technology.
  • 3-year manufacturer's warranty.
*devolo provides you with 15 free SMS messages. For additional notifications, you can purchase a devolo Home Control SMS pack.
The devolo Door/Window Contact gives you versatility when installing it and can be placed discreetly in your smart home. It is reliable in detecting open doors, windows, or drawers and sounds the alarm via text and e-mail if something isn't as it should be. Furthermore, it works hand-in-hand with a series of additional Home Control components. If the window in a room is open, for example, the smart radiator could switch off automatically. The integrated brightness and temperature sensors of the devolo Door/Window Contact can also be the signal generators for the light controls.
devolo Home Control Door / Window Contact - multipurpose sensor
Multipurpose sensor
Sensor Type
Temperature, ambient light, door and window
Wireless - Z-Wave
Frequency Band
868.42 MHz
United Kingdom
3 years warranty
2.8 cm x 2.3 cm x 9.6 cm
Multipurpose sensor
Sensor Type
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple MacOS X 10.9, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
Motion Sensor
Detection Range
10 m
CR123A lithium battery
United Kingdom
Battery Required
CR123A
Warranty
3 years warranty
2.8 cm
2.3 cm
9.6 cm
-10 °C
10 - 85% (non-condensing)
Brand: Devolo
Price Range Ex VAT: 0 - 50
