Your basket is empty
Devolo dLAN Powerline 550 WiFi Network Kit
Quicklinx: BYD3WS00 Mfr#: 9640
Type: Bridge
Speed: 500Mbps
Connectivity: Wireless
Pass-through Socket: No
  • IEEE 802.11n
£124.04 ex VAT
£148.84 inc VAT
The devolo 9640 dLAN 550 WiFi HomePlug Network Kit with range+ Technology provides fast, high-performance Internet connections with significantly longer ranges. This devolo 9640 dLAN 550 WiFi HomePlug Network Kit uses your household electrical wiring to bring you the Internet to any room. Thanks to the intelligent WiFi Move Technology in the devolo 9626 dLAN 550 WiFi HomePlug Adapter, all terminal devices are also automatically connected to the network, giving you top performance WiFi reception for smartphones, tablets etc. in all rooms and on every floor. Along with its compact and unobtrusive design, the devolo 9626 dLAN 550 WiFi HomePlug Adapter provides a LAN port for one additional terminal device such as a smart TV.
Key features
  • Kit includes 1 x devolo 9292 550 Duo+ and 2 x devolo 9626 dLAN 550.
  • dLAN 550 WiFi brings the Internet to any corner of your home over the electrical wiring.
  • Top performance WiFi reception for smartphones, tablets, etc. at speeds of up to 300 Mbps.
  • Powerline connection over the electrical wiring at speeds of up to 500 Mbps.
  • devolo range+ for even greater performance and extended range.
  • LAN port lets you connect another Internet-compatible device (e.g. game console or smart TV) to the Internet.
  • Compact design for convenient placement throughout the home, at any power socket.
  • WiFi Move Technology can automatically connect multiple WiFi adapters to a single Wi-Fi network.
  • Optimal WiFi reception throughout your home—entirely automated.
  • devolo app helps you perfectly manage your personal home network to meet all your needs.
Intelligent WiFi Move Technology
Intelligent WiFi Move Technology provides even more freedom: Now, smartphones, tablets and laptops are automatically connected to the Internet - the best WiFi reception in any room or floor automatically! And the compact and unobtrusive design can be integrated into any residential interior without looking out of place.
High Speed Data Transmission
High-speed data transmission at powerline speeds of up to 500Mbps and a fast Ethernet connection for connecting an additional network device such as Smart TV or game console to one of the HomePlug ports.
devolo dLAN 550 WiFi - Network Kit - bridge - 802.11b/g/n - wall-pluggable
Bridge
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV), IEEE 1901
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Network / Transport Protocol
CSMA/CA
Auto-uplink (auto MDI/MDI-X), MAC address filtering, Wi-Fi Protected Setup (WPS), reset button, 2T2R MIMO technology
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV, IEEE 802.3az, IEEE 1901
AC 230V (50 Hz)
6.8 cm x 4.1 cm x 6.8 cm
Apple MacOS X 10.10, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows 7 / 8 / 8.1 / 10 (64 bits)
3 years warranty
Bridge
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
500 Mbps
Max Range Open Space
300 m
Selectable Channels Qty
13
CSMA/CA
Encryption Algorithm
WPA, WPA2, 128-bit AES
Status Indicators
WLAN, link/activity
Line Properties
Line Coding Format
64 QAM, 256 QAM, BPSK, QPSK, OFDM, 1024 QAM, 4096 QAM
LAN: 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV
Internal power supply
AC 230V (50 Hz)
4.4 Watt
1 x network cable
6.8 cm
4.1 cm
6.8 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
Type: Bridge
Speed: 500Mbps
Brand: Devolo
Price Range Ex VAT: 100 - 150
