Dell XPS 15 9570 Core i7-8750H 32GB 1TB SSD 15.6" Windows 10 Pro
Quicklinx: F520WS00 Mfr#: PH0NG
  • Core i7
  • IEEE 802.11n
The virtually borderless display maximizes screen space by accommodating a 15.6-inch display inside a laptop closer to the size of a 14-inch, thanks to a bezel measuring just 5.7mm. With the UltraSharp 4K Ultra HD display (3840 x 2160), you can see each detail of every pixel without needing to zoom in. And with 6 million more pixels than Full HD and 3 million more than the MacBook Pro, you can edit images with pinpoint accuracy without worrying about blurriness or jagged lines. With 100% Adobe RGB color, the XPS 15 covers a wider color gamut and produces shades of color outside conventional panels so you can see more of what you see in real life. And with over 16 million colors, images appear smoother and color gradients are amazingly lifelike with more depth and dimension. The anti-reflective screen combined with superior 400-nit brightness frees you to enjoy your entertainment outdoors. Plus, the IPS panel provides a wider viewing angle, so you can share your screen without missing a thing.
  • InfinityEdge display
  • Dazzling detail
  • Advanced color
  • Beautiful from any angle
  • Touch friendly
    Tap, swipe and pinch your way around the screen. The optional touch display lets you interact naturally with your technology.
  • Killer Wireless
    The Killer 1535 Wireless-AC adapter provides a strong and reliable Wi-Fi connection and was designed specifically to make your online videos, voice and games play faster and smoother. It automatically detects, classifies and prioritizes network traffic ensuring your most important data takes priority over your other less urgent applications. Killer delivers your critical packets immediately, thus eliminating unnecessary latency and lag.
  • Excellent connectivity
    Thunderbolt 3 multi-use port allows you to charge your laptop, connect to multiple devices (including support for up to two 4K displays) and enjoy data transfers up to 40Gbps, which is 8x faster than USB 3.0. Also includes two USB 3.0 ports.
  • See what you've been missing
    A standard backlit keyboard illuminates your keys so you can stay productive in low-light or no-light rooms while typing.
  • Pinch, zoom and click with confidence
    The precision touch pad prevents jumping and floating cursors, while Accidental Activation Prevention puts a stop to unintentional clicks when your palm hits the touch pad.
  • Windows Hello
    Enjoy a password-free sign-in with the fingerprint reader, which is integrated into the power button that gives you the fastest, most secure way to unlock your laptop. Using your finger, it recognizes you apart from all others. It waves you in with a friendly hello and even works on apps and Microsoft Edge websites.
  • Maximum durability
    Cut with precision from a single block of aluminum for a sturdy, durable chassis in a beautiful design. The Corning Gorilla Glass 4 is twice as damage resistant compared to competitive products.
  • Cool under pressure
    The palm rest is made from carbon fiber. It's strong and thin like aluminum, but lighter and cooler to the touch.
Dell XPS 15 9570 - 15.6" - Core i7 8750H - 32 GB RAM - 1 TB SSD - with 1-year ProSupport
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
32 GB DDR4 (2 x 16 GB)
Storage
1 TB SSD
Display
15.6" touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA GeForce GTX 1050 Ti
Video Memory
4 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
6-cell
Security
Fingerprint reader
Silver
35.7 cm x 23.5 cm x 1.7 cm
1.8 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year - response time: next business day
Bundled Services
1 Year Dell ProSupport
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Intel Turbo Boost Technology 2.0
RAM
32 GB (2 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
1 TB SSD M.2 2280 PCIe
Display
15.6" - IPS
Touchscreen
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Brightness
400 cd/m²
Colour Gamut
100% sRGB
Anti-reflective, Infinity Edge display
Audio & Video
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3266-CG
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Killer Wireless-AC 1535 - M.2 Card
6-cell Lithium Ion
97 Wh
AC Adapter
Input
Output
130 Watt, 19.5 V, 6.67 A
Connections & Expansion
2 x USB 3.1 Gen 1 (PowerShare) , USB-C 3.1 Gen 2 (supports Thunderbolt 3) (Power Delivery) , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Silver
Case Material
Aluminum
Security
Fingerprint reader
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.8 kg
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
