Dell XPS 13 i5-8250U 8GB 256GB 13" Win 10 Pro
Quicklinx: F2LFWS00 Mfr#: 5D74P
Display Size: 13.3in
Processor Model: I5-8250U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£1,267.17 ex VAT
£1,520.60 inc VAT
The small 13-inch laptop with captivating Dell Cinema and next-gen InfinityEdge. Featuring an 8th Gen Intel Quad Core processor in a stunning look.
  • Less border, more pixels
    They have improved every part of the display. Enjoy a screen that seems endless with a 23% thinner InfinityEdge border - just 4mm wide for an 80.7% screen-to-body ratio. See every detail you didn't know you were missing with optional 4K Ultra HD resolution that packs in 8 million pixels.
  • Picture perfect
    By maximizing the color spectrum with 100% sRGB color and a 1500:1 contrast ratio, every shadow takes shape and even the brightest scenes gain definition.
  • Beautiful from any angle
    The anti-reflective screen combined with superior 400-nit brightness frees you to enjoy your entertainment outdoors. Plus, the IPS panel provides a wider viewing angle, so you can share your screen without missing a thing.
  • Small 13-inch laptop
    Your entertainment can go with you everywhere - starting at just 2.67 pounds, the smaller, thinner, lighter XPS 13 is ready for take-off. Perfectly-sized for airplane tray tables, you won't even notice when the passenger in front of you reclines their seat.
  • Star performer
    With 8th Gen Intel Quad Core processors, more cores means increased performance, even with multiple applications running. Plus, Dell Power Manager, engineered by Dell, allows you to select the power mode that dynamically delivers the maximum amount of power from your processor, while intelligently monitoring and managing system temperatures. Add it all up and you get the most powerful 13-inch laptop in its class.
  • Work or play all day
    You'll experience the longest battery life of any 13-inch laptop - very long time on a Full HD model when using Word or Excel.
  • Stunning strength
    The XPS 13 is cut from a single block of aluminum, so it's more durable than a machine that's pieced together. Inspired by the aerospace industry, the carbon fiber and woven glass fiber of the palm rest allow for maximum strength and minimal weight. Corning Gorilla Glass 4 is twice as damage resistant compared to competitive products.
  • Small details, big impact
    Aesthetically, less is more. So they have inlayed a stainless XPS logo, laser-etched the regulatory details and color-matched the feet for a sleeker look. The brightened platinum silver finish truly shines.
  • Leading-edge connectivity
    The Thunderbolt 3 multi-use Type-C ports allow you to charge your laptop, connect to multiple devices (including support for up to two 4K displays) and enjoy data transfers up to 40 Gbps - 8 times that of a USB 3.0.
  • Smarter materials
    Free of materials like cadmium, lead, mercury and some phthalates, it's also EPEAT Gold registered and BFR/PVC-free.
  • Recycle-friendly
    90% of the laptop's parts can be easily recycled or reused, and the white bamboo packaging trays are 100% recyclable.
Dell XPS 13 9370 - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD - with 1-year ProSupport
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB - M.2 2280 SSD NVMe
Optical Drive
No optical drive
Display
13.3" touchscreen 3840 x 2160 / Ultra HD 4K
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
4-cell - up to 19 hours
Security
Fingerprint reader
Silver
30.176 cm x 19.924 cm x 1.16 cm
1.27 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year
Bundled Services
1 Year Dell ProSupport
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz - 1866 MHz
Rated Speed
1866 MHz
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe)
Display
13.3"
Touchscreen
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Corning Gorilla glass 4, Infinity Edge display
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Windows Hello, infrared emitter
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3271-CG
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Killer Wireless-AC 1435
Miracast
4-cell Lithium Ion
52 Wh
Run Time
Up to 19 hours
AC Adapter
Input
Output
45 Watt, DC 5 / 9 / 15 / 20 V
Connections & Expansion
USB-C/DisplayPort (Power Delivery) , 2 x USB-C/Thunderbolt 3 (Power Delivery) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Silver
Case Material
Aluminum
Security
Fingerprint reader
Battery life Indicator
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
Pricing Type
1.27 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Software applications
Dell XPS 13 i5-8250U 8GB 256GB 13 Bundle deal on Dell XPS 13 i5-8250U 8GB 256GB 13" Win 10 Pro
£1,454.81
saving £8.33
£1,366.93
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: Dell
Price Range Ex VAT: 1000 - 1500
