The small 13-inch laptop with captivating Dell Cinema and next-gen InfinityEdge. Featuring an 8th Gen Intel Quad Core processor in a stunning look.
Less border, more pixels
They have improved every part of the display. Enjoy a screen that seems endless with a 23% thinner InfinityEdge border - just 4mm wide for an 80.7% screen-to-body ratio. See every detail you didn't know you were missing with optional 4K Ultra HD resolution that packs in 8 million pixels. -
Picture perfect
By maximizing the color spectrum with 100% sRGB color and a 1500:1 contrast ratio, every shadow takes shape and even the brightest scenes gain definition. -
Beautiful from any angle
The anti-reflective screen combined with superior 400-nit brightness frees you to enjoy your entertainment outdoors. Plus, the IPS panel provides a wider viewing angle, so you can share your screen without missing a thing. -
Small 13-inch laptop
Your entertainment can go with you everywhere - starting at just 2.67 pounds, the smaller, thinner, lighter XPS 13 is ready for take-off. Perfectly-sized for airplane tray tables, you won't even notice when the passenger in front of you reclines their seat. -
Star performer
With 8th Gen Intel Quad Core processors, more cores means increased performance, even with multiple applications running. Plus, Dell Power Manager, engineered by Dell, allows you to select the power mode that dynamically delivers the maximum amount of power from your processor, while intelligently monitoring and managing system temperatures. Add it all up and you get the most powerful 13-inch laptop in its class. -
Work or play all day
You'll experience the longest battery life of any 13-inch laptop - very long time on a Full HD model when using Word or Excel. -
Stunning strength
The XPS 13 is cut from a single block of aluminum, so it's more durable than a machine that's pieced together. Inspired by the aerospace industry, the carbon fiber and woven glass fiber of the palm rest allow for maximum strength and minimal weight. Corning Gorilla Glass 4 is twice as damage resistant compared to competitive products. -
Small details, big impact
Aesthetically, less is more. So they have inlayed a stainless XPS logo, laser-etched the regulatory details and color-matched the feet for a sleeker look. The brightened platinum silver finish truly shines. -
Leading-edge connectivity
The Thunderbolt 3 multi-use Type-C ports allow you to charge your laptop, connect to multiple devices (including support for up to two 4K displays) and enjoy data transfers up to 40 Gbps - 8 times that of a USB 3.0. -
Smarter materials
Free of materials like cadmium, lead, mercury and some phthalates, it's also EPEAT Gold registered and BFR/PVC-free. -
Recycle-friendly
90% of the laptop's parts can be easily recycled or reused, and the white bamboo packaging trays are 100% recyclable.
- Dell XPS 13 9370 - 13.3" - Core i5 8250U - 8 GB RAM - 256 GB SSD - with 1-year ProSupport
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
- Memory
- 8 GB LPDDR3 (provided memory is soldered)
- Storage
- 256 GB SSD - NVMe
- Display
- 13.3" touchscreen 3840 x 2160 / Ultra HD 4K
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 4-cell - up to 19 hours
- Security
- Fingerprint reader
- Silver
- 30.176 cm x 19.924 cm x 1.16 cm
- 1.27 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year
- Bundled Services
- 1 Year Dell ProSupport
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
- Rated Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe)
Display
- 13.3"
- Touchscreen
- Resolution
- 3840 x 2160 (Ultra HD 4K)
- Widescreen
- Corning Gorilla glass 4, Infinity Edge display
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Resolution
- 0.92 Megapixel
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Windows Hello, infrared emitter
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3271-CG
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
Communications
- Wireless
- Wireless Controller
- Killer Wireless-AC 1435
- Miracast
- Technology
- 4-cell Lithium Ion
- Capacity
- 52 Wh
- Run Time
- Up to 19 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, DC 5 / 9 / 15 / 20 V
Connections & Expansion
- USB-C (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB-C (supports Thunderbolt 3) (Power Delivery) , Headphone/microphone combo jack
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Silver
- Case Material
- Aluminum
- Security
- Battery life Indicator
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- USB-C power adapter
- Pricing Type
- 1.27 kg
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 110 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 160 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
Get more from your purchase from one of our essential accessories
Dicota Privacy filter 2-Way for Laptop 13.3" Wide (16:9), side-mounted | In Stock | £28.79 |
