Dell XPS 13 9380 Intel Core i7-8565U 8GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: F6XCWS00 Mfr#: 38TDD
  • Core i7
  • IEEE 802.11n
Your entertainment can go with you everywhere - the smaller, thinner XPS 13 is ready for take-off. So perfectly sized for airplane tray tables, you won't even notice when the passenger in front of you reclines their seat.
  • Revolutionary webcam construction
    The webcam of XPS 13 9380 isn't just smaller (only 2.25mm) - it's also better. A four-element lens uses more elements than a typical webcam to deliver sharp video in all areas of the frame, while temporal noise reduction uses advanced noise reduction, significantly improving video quality, especially in dim lighting conditions. Finally, the lens is assembled with precise machinery to ensure all points of the image are in focus.
  • Less border, more pixels
    Enjoy a screen that seems endless with an InfinityEdge display, enabling a 13.3" screen in an 11-inch form factor with an 80.7% screen-to-body ratio. See every detail you didn't know you were missing.
  • Vibrant colors
    By maximizing the color spectrum with 100% sRGB color and a 1500:1 contrast ratio, every shadow takes shape and even bright scenes gain definition.
  • Beautiful from every angle
    The anti-reflective screen combined with superior 400-nit brightness frees you to enjoy your entertainment outdoors. Plus, the IPS panel provides a wider viewing angle, so you can share your screen without missing a thing.
  • Stunning strength
    The XPS 13 is cut from a single block of aluminum, so it's more durable than a machine that's pieced together. Carbon fiber, inspired by the aerospace industry, and woven glass fiber of the palm rest, allow for maximum strength and minimal weight. Corning Gorilla Glass 4 is twice as damage resistant compared to competitive products.
  • Cooler than ever
    The XPS 13 is the first laptop built with GORE Thermal Insulation, which provides thermal conductivity levels lower than air in a thin, flexible format. While the Gore insulation directs heat out of the device, dual fans and heat pipes further lower the temperature of your XPS, enabling greater performance in a thinner form factor.
  • Advanced connectivity
    The Thunderbolt 3 multi-use Type-C ports allow you to charge your laptop, connect to multiple devices (including support for up to two 4K displays) and enjoy data transfers up to 40Gbps - 8 times that of a USB 3.0.
Dell XPS 13 9380 - 13.3" - Core i7 8565U - 8 GB RAM - 256 GB SSD - with 1-year ProSupport
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache
8 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD - NVMe
Display
13.3" LED backlight 1920 x 1080 / Full HD @ 60 Hz
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
Bluetooth 4.2, 802.11a/b/g/n/ac Wave 2
4-cell
Security
Fingerprint reader
Silver
30.176 cm x 19.924 cm x 1.163 cm
1.27 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year
Bundled Services
1 Year Dell ProSupport
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
2133 MHz
Rated Speed
2133 MHz
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
13.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Image Brightness
400 cd/m²
Anti-glare, Infinity Edge display, Wide Viewing Angle, 30 ms response rate, ±85° horizontal viewing angle, ±85° vertical viewing angle, 0.153 mm pixel pitch
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.9 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
Fixed focus
Sound
Stereo speakers, quad array microphone
Codec
Realtek ALC3271-CG
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Killer Wireless-AC 1435
4-cell Lithium Ion
52 Wh
AC Adapter
Input
Output
45 Watt, 5 / 9 / 15 / 20 V
Connections & Expansion
USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , 2 x USB-C (supports Thunderbolt 3) (Power Delivery) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Silver
Security
Fingerprint reader
Battery life Indicator
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
Pricing Type
1.27 kg
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Essential Accessories (1)
Get more from your purchase from one of our essential accessories
F6XC Dicota Privacy filter 2-Way for Laptop 13.3" Wide (16:9), side-mounted In Stock £28.79
Other bundles (1)
F6XC Dell Slim DW316 USB External DVD Drive In Stock £35.58
