Dell XPS 13 2-in-1 i7-8500Y 16GB 512GB SSD 13" Win 10 Pro
Quicklinx: F2LBWS00 Mfr#: GV635
  • Core i7
  • IEEE 802.11n
The XPS 13 Ultrabook is slim and features a 13.3" HD display cleverly fit into a footprint that's similar to an 11" laptop. XPS 13 Ultrabook feels as good as it looks, thanks to a comfort-designed keyboard and a sleek, gesture-enabled glass touch pad.
The XPS 13 Ultrabook boots from cold in as little as 12 seconds. Whatever state your laptop is in, it comes back in a snap, less than 3 seconds when it's in sleep mode and less than 5 seconds from deep sleep.
  • Thoughtful design
    It goes beyond beauty. Bonded Corning Gorilla glass, machined aluminum and carbon fiber are incorporated to enhance the performance of this Ultrabook.
  • Strikingly thin, with more room to view
    The XPS 13 Ultrabook is a slim 6 mm (0.24) at its thinnest point - only 18 mm (0.71) at its thickest point - and features a 13.3" HD display cleverly fit into a footprint that's similar to an 11" laptop.
  • Refined features
  • Full HD display
    Enjoy a state-of-the-art viewing experience with the Full HD 1080p display.
  • Sharper detail
    You can experience sharper detail with twice the number of pixels than a 720p display.
  • Brilliant display
    The 350-nit brightness is up to 75% brighter than a typical 200-nit panel, so movie viewing and web surfing is enhanced with exceptional illumination.
  • Wide viewing angle
    The full 178-degree viewing angle allows you to easily share content with friends and family.
  • Turns on instantly
  • Always up to date
    Intel Smart Connect technology keeps your email, contacts, calendar and social networks up to date, even when your XPS 13 Ultrabook is in sleep mode.
Dell XPS 13 9365 2-in-1 - 13.3" - Core i7 8500Y - 16 GB RAM - 512 GB SSD - with 1-year ProSupport
Notebook - flip design
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i7 (8th Gen) 8500Y / 1.5 GHz (4.2 GHz) / 4 MB Cache
16 GB LPDDR3
Storage
512 GB SSD
Display
13.3" touchscreen 3200 x 1800 / QHD+
Graphics
Intel UHD Graphics 615
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
4-cell
Security
Fingerprint reader
Silver
30.42 cm x 19.85 cm x 1.37 cm
1.24 kg
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year
Bundled Services
1 Year Dell ProSupport
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
4.2 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
16 GB
LPDDR3 SDRAM
Speed
1866 MHz
Rated Speed
1866 MHz
Storage
Main Storage
512 GB SSD M.2 PCIe
Display
13.3"
Touchscreen
Resolution
3200 x 1800 (QHD+)
Widescreen
Corning Gorilla glass NBT, Infinity Edge display
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
74.6 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3271
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
4-cell Lithium Ion
46 Wh
AC Adapter
Input
Output
30 Watt
Connections & Expansion
USB-C 3.1 (supports DisplayPort Alt Mode) (PowerShare) , Thunderbolt 3 (PowerShare) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC UHS)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Silver
Security
Fingerprint reader
Battery life Indicator
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
Pricing Type
1.24 kg
Sustainability Information
ENERGY STAR Certified
Bundled Services
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
