Dell X1052P Switch L2+ Managed 48 x 10/100/1000 4 x10 GigabitSFP+
Quicklinx: BTV0WS00 Mfr#: 210-AEIP
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£640.87 ex VAT
£769.04 inc VAT
Easily manage your office network with 1GbE and 10GbE switches that offer enterprise-class features and intuitive, GUI-based management.
  • Elegant interface, effortless management
    The intuitive graphical user interface (GUI) of Dell Networking X-series switches makes setup and management simple for network administrators. Based on extensive usability testing, the design of everything from navigation to menu structures and help tips is inspired by the way IT professionals think and work, making the interface a pleasure to use regularly or occasionally.
  • Save time with smart features
    Streamlined tools, step-by-step wizards and a customizable dashboard help you manage faster. Rapidly configure and tune network performance with purpose-built tools and wizards. Optimize traffic with automation - use point-and-click batch routines for specific applications such as unified communications. Gain visibility with a detailed dashboard providing a single, customizable view into common tasks, alerts, port status and network visualization. Skip the learning curve and use familiar commands and alerts similar to PCs and servers.
  • Minimize risk with enhanced visibility and control
    Enhanced network traffic visibility and troubleshooting reduces risk of network downtime. Monitor and resolve issues with "actionable monitoring, " a guided continuous workflow from issue identification to resolution. Reduce configuration errors and eliminate extra steps with help from multi-port batch routines and port profiles for common devices. Optimize cloud services and onsite network applications with security and traffic-priority features.
  • Easy integration with your network
    Pick the right switch for your network. PoE+ models provide additional deployment flexibility, allowing you to connect, auto-configure and power phones, cameras, compact switches and other network devices.
Dell EMC Networking X1052P - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - L2+ - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
360 W
Performance
Switching fabric bandwidth: 176 Gbps , Forwarding performance: 131 Mpps
MAC addresses: 16000 , LAG groups: 12 , Priority queues per port: 8 , Virtual interfaces (VLANs): 4096 , Maximum member ports per LAG: 8
MAC Address Table Size
16K entries
Remote Management Protocol
SNMP 1, SNMP 2, RMON, SNMP 3, HTTP, CLI
Auto-negotiation, VLAN support, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), DNS server, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), SNMP trap, static routing, GARP VLAN Registration Protocol (GVRP), SNMP support, ARP inspection, Head of Line Blocking Prevention, Back Pressure Support, Proprietary Protocol Filtering
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
43.4 cm x 40.7 cm x 43.5 cm
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
360 W
Performance
16K entries
Authentication Method
RADIUS, TACACS+
48 x 1000Base-T 12 ports (PoE+) / 24 ports (PoE) , 4 x 10Gbit LAN SFP+ , 1 x USB Type A management , 1 x micro-USB management
Internal power supply
Power Provided
525 Watt
82 Watt
43.4 cm
40.7 cm
43.5 cm
Limited warranty - lifetime
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BTV0 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.27
BTV0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.23
BTV0 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.04
Ports: 48
Managed: Yes
POE: PoE+
Brand: Dell
Price Range Ex VAT: 500 - 750
