Easily manage your office network with 1GbE and 10GbE switches that offer enterprise-class features and intuitive, GUI-based management.
Elegant interface, effortless management
The intuitive graphical user interface (GUI) of Dell Networking X-series switches makes setup and management simple for network administrators. Based on extensive usability testing, the design of everything from navigation to menu structures and help tips is inspired by the way IT professionals think and work, making the interface a pleasure to use regularly or occasionally. -
Save time with smart features
Streamlined tools, step-by-step wizards and a customizable dashboard help you manage faster. Rapidly configure and tune network performance with purpose-built tools and wizards. Optimize traffic with automation - use point-and-click batch routines for specific applications such as unified communications. Gain visibility with a detailed dashboard providing a single, customizable view into common tasks, alerts, port status and network visualization. Skip the learning curve and use familiar commands and alerts similar to PCs and servers. -
Minimize risk with enhanced visibility and control
Enhanced network traffic visibility and troubleshooting reduces risk of network downtime. Monitor and resolve issues with "actionable monitoring," a guided continuous workflow from issue identification to resolution. Reduce configuration errors and eliminate extra steps with help from multi-port batch routines and port profiles for common devices. Optimize cloud services and onsite network applications with security and traffic-priority features.
- Dell Networking X1026P - switch - 24 ports - Managed
- Switch - 24 ports - L2+ - Managed
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 2 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- Performance
- Switching fabric bandwidth: 52 Gbps , Forwarding performance: 38.7 Mpps
- Capacity
- MAC addresses: 16000 , LAG groups: 12 , Priority queues per port: 4 , Virtual interfaces (VLANs): 4096 , Maximum member ports per LAG: 8
- MAC Address Table Size
- 16K entries
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON, SNMP 3, HTTP, CLI
- Auto-negotiation, VLAN support, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), DNS server, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), SNMP trap, static routing, GARP VLAN Registration Protocol (GVRP), SNMP support, ARP inspection, Head of Line Blocking Prevention, Back Pressure Support, Proprietary Protocol Filtering
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 20.9 cm x 45 cm x 41.25 cm
- Limited lifetime warranty
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- Performance
- Capacity
- 16K entries
- Authentication Method
- RADIUS, TACACS+
- 24 x 1000Base-T 12 ports (PoE+) / 24 ports (PoE) , 2 x Gigabit LAN SFP , 1 x USB Type A management , 1 x micro-USB management
- Power Device
- Internal power supply
- Power Provided
- 450 Watt
- Voltage Required
- 37 Watt
- 20.9 cm
- 45 cm
- 41.25 cm
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
Dell SFP (mini-GBIC) transceiver module GigE 1000Base-SX | In Stock | £93.13 |
