Easily manage your office network with 1GbE and 10GbE switches that offer enterprise-class features and intuitive, GUI-based management.
Elegant interface, effortless management
The intuitive graphical user interface (GUI) of Dell Networking X-Series switches makes setup and management simple for network administrators. Based on extensive usability testing, the design of everything from navigation to menu structures and help tips is inspired by the way IT professionals think and work, making the interface a pleasure to use regularly or occasionally. -
Easy integration with your network
Pick the right switch for your network. Choose from a broad selection of models with rich feature sets and a variety of port counts. Power over Ethernet (PoE) and PoE+ models provide additional deployment flexibility, allowing you to connect, auto-configure and power phones, cameras, compact switches and other network devices.
- Dell Networking X1018 - switch - 16 ports - Managed
- Switch - 16 ports - L2+ - Managed
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000 + 2 x Gigabit SFP
- Performance
- Switching fabric bandwidth: 36 Gbps , Forwarding performance: 26.8 Mpps
- Capacity
- MAC addresses: 16000 , LAG groups: 12 , Priority queues per port: 4 , Virtual interfaces (VLANs): 4096 , Maximum member ports per LAG: 8
- MAC Address Table Size
- 16K entries
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON, SNMP 3, HTTP, CLI
- Auto-negotiation, VLAN support, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Uni-Directional Link Detection (UDLD), DNS server, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), SNMP trap, static routing, GARP VLAN Registration Protocol (GVRP), SNMP support, ARP inspection, Head of Line Blocking Prevention, Back Pressure Support, Proprietary Protocol Filtering
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ac, IEEE 802.1s, IEEE 802.1v, IEEE 802.1ab (LLDP)
- Power
- AC 120/230 V (50/60 Hz)
- 20.9 cm x 25 cm x 41.25 cm
- Limited lifetime warranty
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- Capacity
- 16K entries
- Authentication Method
- RADIUS, TACACS+
- 16 x 1000Base-T , 2 x Gigabit LAN SFP , 1 x USB Type A management , 1 x micro-USB output management
- Power Device
- Internal power supply
- Power Provided
- 40 Watt
- Voltage Required
- 21.5 Watt
- 20.9 cm
- 25 cm
- 41.25 cm
- Limited warranty - lifetime
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
Dell SFP (mini-GBIC) transceiver module GigE 1000Base-SX | In Stock | £76.88 |
