Wyse Z90D7 is a super high-performance thin client for virtual desktop environments. Featuring a revolutionary, unified engine that eliminates performance constraints, the Z90D7 achieves incredible speed and power for the most demanding applications, rich graphics and HD video. Take a unit from box to productivity in minutes. The Z90D7 is an ideal thin client for the most demanding mix of virtual desktop or cloud applications.
Performance: advanced processing blows away everything
It's fast. At the heart of the Wyse Z90 lies an engine, where all the major system elements - CPU cores, vector engines, and a unified video decoder for HD decoding tasks - live on the same piece of silicon. This design concept eliminates one of the fundamental constraints that limit performance. Whether you want the best 2D or 3D graphics, HD video, or the ability to embed custom Windows applications that execute right on the Z90, you'll have power to spare. -
Ease of use: it's the thin client that does it all, without making you do it all
The Wyse Z90 is based on Wyse-enhanced Windows Embedded, providing broad functionality for a dynamic world. The familiar user interface, integrated Windows Media Player, Internet Explorer, and full support for embedded Windows applications make the Z90 a powerhouse of capability whether you need a thin client for virtual desktop or cloud applications, a more-secure, solid state PC for custom applications, or a secure work from home station for telecommuters.
- Dell Wyse Z90D7 Thin Client - DTS - G-T56N 1.65 GHz - 4 GB - flash 16 GB
- Thin client - desktop slimline
- Processor
- 1 x AMD G-T56N 1.65 GHz (Dual-Core)
- RAM
- 4 GB DDR3 SDRAM
- Hard Drive
- Flash 16 GB
- Optical Storage
- No optical drive
- Graphics Controller
- AMD Radeon HD 6320
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows Embedded Standard 7
- 4.7 cm x 22.5 cm x 20 cm
- 1.12 kg
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- Limited warranty - 3 years
- Thin client
- Product Form Factor
- Desktop slimline
- Built-in Devices
- Speaker
Processor / Chipset
- CPU
- AMD G-T56N
- Clock Speed
- 1.65 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 4 GB
- Technology
- DDR3 SDRAM
Hard Drive
- Flash
- Capacity
- 16 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DVI, DisplayPort
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 48 kHz
- Integrated
- Data Link Protocol
- 1 x DisplayPort , 1 x DVI-I , 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (1 in front) , 1 x microphone (1 in front) , 2 x serial , 1 x parallel , 1 x PS/2 keyboard
- Included Accessories
- Vertical stand
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE
- Power adapter
- Voltage Required
Operating System / Software
- OS Provided
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 4.7 cm
- 22.5 cm
- 20 cm
- 1.12 kg
- 10 °C
- 40 °C
- 10 - 95% (non-condensing)
