Product
Brand
Dell Wyse 3020 Thin Client Marvell ARMADA DC 2GB 4GB Thin OS
Quicklinx: C5S5WS00 Mfr#: 4DG9X
Dell Wyse Thin Client Desktop 3000 Series - Strong Desktop Performance on a Budget. Simplified performance. Efficient, easy-to-use thin clients for cost-effective virtual desktop sites.
Dell Wyse 3020 - DTS - ARMADA PXA2128 1.2 GHz - 2 GB - 4 GB
Thin client - desktop slimline
Bundled Services
3 Years Dell Collect and Return Service
1 x Marvell ARMADA PXA2128 / 1.2 GHz (Dual-Core)
RAM
2 GB DDR3 SDRAM
Hard Drive
1 x flash 4 GB
Audio Output
Stereo
GigE
OS Provided
Wyse Thin OS
17.6 cm x 12.1 cm x 3.5 cm
500 g
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Thin client
Bundled Services
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
2 GB
DDR3 SDRAM
Hard Drive
Flash
1 x 4 GB
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
48 kHz
Input Device
Mouse (on selected markets only)
Mouse
Optical
USB
1 x DVI-I , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out , 1 x VGA (with adapter) , 1 x DVI-D
Horizontal feet
DVI-VGA adapter
Theft/Intrusion Protection
RoHS, WEEE
Pricing Type
Power adapter
Nominal Voltage
Power Provided
30 Watt
10 Watt
Operating System / Software
OS Provided
Wyse Thin OS
ENERGY STAR Certified
17.6 cm
12.1 cm
3.5 cm
500 g
10 °C
35 °C
10 - 95% (non-condensing)
C5S5 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.08
C5S5 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.39
C5S5 C2G 2-Port USB 2.0 Manual Switch In Stock £17.67
C5S5 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.21
C5S5 C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.75
C5S5 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £15.46
C5S5 C2G USB 2.0 To Fast Ethernet Adapter In Stock £20.39
