Dell Wyse Thin Client Desktop 3000 Series - Strong Desktop Performance on a Budget. Simplified performance. Efficient, easy-to-use thin clients for cost-effective virtual desktop sites.
Easy to use and manage
Build out a simple or vast virtual desktop infrastructure (VDI) and stay within your budget using Wyse 3000 series thin clients. This easy-to-use family of clients for Citrix, Microsoft, VMware or Wyse vWorkspace environments includes models that are available with virus-immune Wyse ThinOS or Wyse enhanced Ubuntu Linux. -
Exceptional functionality
Empower your team with enterprise-class thin clients on an entry-level budget. 3000 series thin clients feature a wealth of premium Wyse cloud client features, and unlike traditional budget clients, 3000 series thin clients are ready to connect to almost any environment, including web-based applications and services. 3000 series thin clients can quickly process virtually any daily task with powerful System-on-Chip (SoC) processors. A built-in hardware media processor helps deliver smooth imagery, bi-directional audio and flash playback performance. The 3020 thin client offers even greater functionality with support for up to two digital displays, a dual-band Wi-Fi option and Microsoft RemoteFX certification for high-end graphics. -
Environmentally-conscious for long-term value
Designed for cost-effective virtual desktop deployments, the Wyse 3000 series thin clients deliver great value from day one with minimal initial investment and power-efficient operation that help lower your cost of ownership.
- Dell Wyse 3020 - DTS - ARMADA PXA2128 1.2 GHz - 2 GB - 4 GB
- Thin client - desktop slimline
- Bundled Services
- 3 Years Dell Collect and Return Service
- Processor
- 1 x Marvell ARMADA PXA2128 / 1.2 GHz (Dual-Core)
- RAM
- 2 GB DDR3 SDRAM
- Hard Drive
- 1 x flash 4 GB
- Optical Storage
- No optical drive
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Wyse Thin OS
- Black
- 17.6 cm x 12.1 cm x 3.5 cm
- 500 g
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Thin client
- Bundled Services
- Product Form Factor
- Desktop slimline
- Black
Processor / Chipset
- CPU
- Marvell ARMADA PXA2128 / 1.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 2 GB
- Technology
- DDR3 SDRAM
Hard Drive
- Flash
- Capacity
- 1 x 4 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- DVI
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 48 kHz
Input Device
- Mouse (on selected markets only)
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- 1 x DVI-I , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out , 1 x DVI-D
- Included Accessories
- Horizontal feet
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- RoHS, WEEE
- Pricing Type
- Power adapter
- Nominal Voltage
- Power Provided
- 30 Watt
- 10 Watt
Operating System / Software
- OS Provided
- Wyse Thin OS
- ENERGY STAR Certified
- 17.6 cm
- 12.1 cm
- 3.5 cm
- 500 g
- 10 °C
- 35 °C
- 10 - 95% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.89 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £4.51 |
C2G 4-Port USB 2.0 Aluminum Hub | In Stock | £19.32 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £16.73 |
C2G USB 2.0 To Fast Ethernet Adapter | In Stock | £21.28 |
C2G USB Superbooster Extender Kit | In Stock | £37.81 |
C2G Trulink® USB to Gigabit Ethernet Adapter | In Stock | £23.38 |
C2G USB to HDMI Adapter with Audio Up To 1080p | In Stock | £42.30 |
