Product
Dell Wyse 3020 Thin Client Marvell ARMADA DC 2GB 4GB Thin OS
Quicklinx: C5S5WS00 Mfr#: 4DG9X
Dell Wyse Thin Client Desktop 3000 Series - Strong Desktop Performance on a Budget. Simplified performance. Efficient, easy-to-use thin clients for cost-effective virtual desktop sites.
  • Easy to use and manage
    Build out a simple or vast virtual desktop infrastructure (VDI) and stay within your budget using Wyse 3000 series thin clients. This easy-to-use family of clients for Citrix, Microsoft, VMware or Wyse vWorkspace environments includes models that are available with virus-immune Wyse ThinOS or Wyse enhanced Ubuntu Linux.
  • Exceptional functionality
    Empower your team with enterprise-class thin clients on an entry-level budget. 3000 series thin clients feature a wealth of premium Wyse cloud client features, and unlike traditional budget clients, 3000 series thin clients are ready to connect to almost any environment, including web-based applications and services. 3000 series thin clients can quickly process virtually any daily task with powerful System-on-Chip (SoC) processors. A built-in hardware media processor helps deliver smooth imagery, bi-directional audio and flash playback performance. The 3020 thin client offers even greater functionality with support for up to two digital displays, a dual-band Wi-Fi option and Microsoft RemoteFX certification for high-end graphics.
  • Environmentally-conscious for long-term value
    Designed for cost-effective virtual desktop deployments, the Wyse 3000 series thin clients deliver great value from day one with minimal initial investment and power-efficient operation that help lower your cost of ownership.
Dell Wyse 3020 - DTS - ARMADA PXA2128 1.2 GHz - 2 GB - 4 GB
Thin client - desktop slimline
Bundled Services
3 Years Dell Collect and Return Service
1 x Marvell ARMADA PXA2128 / 1.2 GHz (Dual-Core)
RAM
2 GB DDR3 SDRAM
Hard Drive
1 x flash 4 GB
Optical Storage
No optical drive
Audio Output
Stereo
GigE
OS Provided
Wyse Thin OS
17.6 cm x 12.1 cm x 3.5 cm
500 g
Pricing Type
Build To Stock (BTS)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Thin client
Bundled Services
Product Form Factor
Desktop slimline
Processor / Chipset
CPU
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
2 GB
DDR3 SDRAM
Hard Drive
Flash
1 x 4 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Video Interfaces
DVI
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
48 kHz
Input Device
Mouse (on selected markets only)
Mouse
Optical
USB
1 x DVI-I , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out , 1 x VGA (with adapter) , 1 x DVI-D
Horizontal feet
DVI-VGA adapter
Theft/Intrusion Protection
RoHS, WEEE
Pricing Type
Power adapter
Nominal Voltage
Power Provided
30 Watt
10 Watt
Operating System / Software
OS Provided
Wyse Thin OS
ENERGY STAR Certified
17.6 cm
12.1 cm
3.5 cm
500 g
10 °C
35 °C
10 - 95% (non-condensing)
C5S5 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.10
C5S5 C2G 5m USB 2.0 A/B Cable - Black In Stock £4.49
C5S5 C2G 2-Port USB 2.0 Manual Switch In Stock £17.70
C5S5 C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £12.23
C5S5 C2G 4-Port USB 2.0 Aluminum Hub In Stock £19.32
C5S5 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £16.20
C5S5 C2G USB 2.0 To Fast Ethernet Adapter In Stock £20.61
