Dell Wyse Thin Client Desktop 3000 Series - Strong Desktop Performance on a Budget. Simplified performance. Efficient, easy-to-use thin clients for cost-effective virtual desktop sites.
- Dell Wyse 3010 - DTS - ARMADA 510 1 GHz - 1 GB - 0 GB
- Thin client - desktop slimline
- Bundled Services
- 3 Years Dell Collect and Return Service
- Processor
- 1 x Marvell ARMADA 510 / 1 GHz
- RAM
- 1 GB DDR3 SDRAM
- Hard Drive
- No HDD
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Wyse Thin OS
- 17.7 cm x 11.9 cm x 2.5 cm
- 450 g
- Pricing Type
- Build To Stock (BTS)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years
- Thin client
- Bundled Services
- Product Form Factor
- Desktop slimline
- Black
Processor / Chipset
- CPU
- Marvell ARMADA 510 / 1 GHz
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 1 GB
- Technology
- DDR3 SDRAM
Hard Drive
- No HDD
Monitor
- Monitor Type
- None.
Graphics Controller
- Video Interfaces
- DVI
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 48 kHz
Input Device
- Mouse (on selected markets only)
Mouse
- Technology
- Optical
- Interface
- USB
- Data Link Protocol
- 1 x DVI-I , 4 x USB 2.0 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x microphone (1 in front) , 1 x audio line-out (1 in front) , 1 x VGA (with adapter)
- Included Accessories
- Horizontal feet
- Cables Included
- DVI-VGA adapter
- Theft/Intrusion Protection
- Mounting Interface
- RoHS, WEEE
- Pricing Type
- Power adapter
- Nominal Voltage
- Power Provided
- 30 Watt
- 7 Watt
Operating System / Software
- OS Provided
- Wyse Thin OS
- ENERGY STAR Certified
- 17.7 cm
- 11.9 cm
- 2.5 cm
- 450 g
- 10 °C
- 35 °C
- 10 - 95% (non-condensing)
