Dell Vostro 5581 Intel Core i5-8265U 8GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: F95DWS00 Mfr#: TKW0R
Display Size: 15.6in
Processor Model: I5-8265U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
Sorry but this product has been discontinued.
View used stock
A 15" laptop that combines seamless connectivity, security options and an expansive screen for a professional task master you can count on.
  • Two-sided narrow border
    With thin side borders, it's easier to focus on the screen and therefore the task at hand.
  • High definition from every angle
    The FHD display looks great from virtually any perspective, thanks to In-Plane Switching (IPS) technology that enables accurate, wide-angle viewing.
  • Better collaboration
    SmartByte prioritizes streaming above other applications while Waves Maxx AudioPro offers true-to-life sound quality for a seamless video conference experience.
  • Power saving
    Peak shift reduces power consumption by automatically switching the system to battery power, even when plugged into a direct power source.
  • Unite all your devices
    A wide array of ports, SD card reader and Gigabit Ethernet allow you stay connected to a variety of devices.
  • Thin and light
    The lightweight design has been streamlined to give you a stylish look and feel.
Dell Vostro 5581 - 15.6" - Core i5 8265U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Silver
36.11 cm x 24.9 cm x 2.03 cm
1.9 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year
Bundled Services
1 Year Dell Collect and Return Service
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) PCIe
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Anti-glare, ±80° horizontal viewing angle, ±80° vertical viewing angle, 141 ppi
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Image Sensor Type
CMOS
Video Resolutions
1280 x720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, 74.9 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Multi-touch touchpad
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111
3-cell Lithium Ion
42 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V, 2.31 A
Connections & Expansion
2 x USB 3.1 Gen 1 , USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial), Windows 10 64-bit USB Key
Silver
Security
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.9 kg
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
40 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F95D 041545
Condition: Customer return - item has been repaired under warranty by the manufacturer
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £401.76
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Touchscreen: No
Type: Laptop
Brand: Dell
Stock Status: Clearance
Stock Status: Used Stock
Price Range Ex VAT: 300 - 500
