Dell Vostro 5490 Intel Core i5-10210U 8GB 256GB 14" W10P
Quicklinx: FQMJWS00 Mfr#: 4C8XR
  • Core i5
  • IEEE 802.11n
Your laptop lifts slightly off the table when open past a 135-degree angle, allowing for improved air circulation and a more comfortable typing experience.
  • Redesigned hinge
  • Ready and waiting
    A lid-open sensor will turn on your laptop, even when completely off, so you can access what you need, when you need it.
  • Durable thinness
    All your business travel just got seamless thanks to a compact and durable aluminum cover that stays secure in your carry-on, backpack or bag.
  • Minimize distractions
    A 3-sided narrow border enhances your screen so that you can collaborate in online meetings or work on your projects in style.
  • Adaptive Thermals
    Your system is smart enough to know when it is in your hands, lap or on a desk. This allows it to intelligently adapt its thermal profiles to the situation. In-hand discomfort is avoided, and full power is unleashed when stationary on a desk for maximum productivity.
  • Temporal noise reduction
    Using advanced noise reduction, video quality is significantly improved, especially in dim lighting conditions.
Dell Vostro 5490 - 14" - Intel Core i5 - 10210U - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - NVMe
Display
14" LED backlight 1920 x 1080 / Full HD @ 60 Hz - 158 ppi
Graphics
Intel UHD Graphics
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
3-cell
Lid-open sensor
Security
Fingerprint reader
Grey
32.177 cm x 22.765 cm x 1.83 cm
1.49 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Dell Collect and Return Service
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i5 (10th Gen) 10210U / 1.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (provided memory is soldered)
Max RAM Supported
24 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
158
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Colour Gamut
45% NTSC
Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle, Narrow Border Display, 35 ms response rate, 0.161 mm pixel pitch
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, 74.9 degrees, RGB camera
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Audio Features
Output: MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 9462
Network Interface
Gigabit Ethernet
3-cell lithium polymer
42 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V, 2.31 A
Connections & Expansion
Interfaces Details
LAN , 2 x USB 3.1 Gen 1 , USB 2.0 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (PowerShare) , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (microSD)
Software
Software Included
McAfee (12 months subscription)
Grey
Integrated Options
Lid-open sensor
Security
Fingerprint reader
ExpressCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
FIPS 140-2
Pricing Type
1.49 kg
Sustainability Information
TCO Certified
Bundled Services
10 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms
Shock Tolerance (non-operating)
160 g @ 2 ms
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
