A small, light 14" laptop that combines seamless connectivity and security options for a professional task master you can count on.
Two-sided narrow border
With thin side borders, it's easier to focus on the screen and therefore the task at hand. -
High definition from every angle
With the FHD display, the In-Plane Switching (IPS) technology enables accurate, wide-angle viewing. -
Better collaboration
SmartByte prioritizes streaming above other applications while Waves Maxx AudioPro offers true-to-life sound quality for a seamless video conference experience. -
Power saving
Peak shift reduces power consumption by automatically switching the system to battery power, even when plugged into a direct power source. -
Unite all your devices
A wide array of ports, SD card reader and Gigabit Ethernet allow you stay connected to a variety of devices. -
Thin and light
The lightweight design has been streamlined to give you a stylish look and feel.
- Dell Vostro 5481 - 14" - Core i5 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD
- Display
- 14" LED backlight 1920 x 1080 / Full HD - 157 ppi
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Silver
- 32.49 cm x 23.2 cm x 1.82 cm
- 1.55 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year - pick-up and return
- Bundled Services
- 1 Year Dell Collect and Return Service
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Pixel Density (ppi)
- 157
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, ±80° horizontal viewing angle, ±80° vertical viewing angle
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - 1280 x 720
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 3165
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111
- Technology
- 3-cell Lithium Ion
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V, 2.31 A
Connections & Expansion
- 2 x USB 3.1 Gen 1 , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB 2.0 , HDMI , LAN , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial)
- Silver
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.55 kg
- Bundled Services
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
- Shock Tolerance (operating)
- 105 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.26 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.37 g @ RMS (random)
