Dell Vostro 3581 Intel Core i3-7020U 4GB 1TB 15.6" Windows 10 Professional 64-bit
Quicklinx: F958WS00 Mfr#: 643XV
  • Core i3
  • IEEE 802.11n
Laptop with security and connectivity small business demands. Featuring fast processors, PC/smartphone integration and a numeric keypad.
  • An array of ports
    Connect to a TV or monitor with the VGA port, and easily play DVDs with the optical disk drive.
  • Simply secure
    With a fingerprint reader on the power button, sign-on is easy, fast and safe.
Dell Vostro 3581 - 15.6" - Core i3 7020U - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Pro 64-bit
Intel Core i3 (7th Gen) 7020U / 2.3 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD-Writer
Display
15.6" 1366 x 768 / HD @ 60 Hz
Graphics
Intel HD Graphics 620
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1, Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
38 cm x 25.8 cm x 2.27 cm
2 kg
Pricing Type
Build To Stock (BTS)
Limited warranty - 1 year
Bundled Services
1 Year Dell Collect and Return Service
Notebook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Optical Drive
DVD-Writer
Display
15.6" - TN
Resolution
1366 x 768 (HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Bezel Type
Raised
Ultra Slim Design, anti-glare, ±40° horizontal viewing angle
Audio & Video
Graphics Processor
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, fixed focus, 78.6 degrees
Sound
Stereo speakers, microphone
Codec
Realtek ALC3246
High Definition Audio
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Numeric Keypad
Communications
Wireless
Wireless Controller
Dell Wireless 1810
Network Interface
Ethernet
3-cell Lithium Ion
42 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V, 2.31 A
Connections & Expansion
HDMI , Headphone/microphone combo jack , USB 2.0 , 2 x USB 3.1 Gen 1 , LAN , VGA
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial), McAfee (30 days trial)
Security
Noise reducing microphone
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
2 kg
Bundled Services
10 - 90% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
