Meet the laptop devoted to small business. Vostro 3000 is designed to keep your workday running smoothly.
Powerfully efficient: Work through your day quickly and conveniently with the latest Intel Core processor. This ultra-low voltage processor delivers power and an efficient performance.
Simple data entry: Breeze through spreadsheets with a 10-key number pad.
Sophisticated, practical design: The micro-striped, textured cover is less prone to scratches and easy to grip, so your laptop will stay looking sleek and professional.
Power up your business
Your business needs power. It needs speed and performance. Vostro laptops are your full-featured, business solution - an uncompromising mix of power and portability. -
Designed to last
With a wide, durable metal hinge for added support, and a sturdy aluminum casing, Vostro laptops are a smart investment in your business. -
Work virtually anywhere, anytime
Connecting and collaborating on-the-go has never been easier.
- Dell Vostro 3559 - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit + Windows 10 Pro 64-bit Licence
- Processor
- Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD-Writer
- Display
- 15.6" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 520
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 4-cell
- Black
- 38 cm x 26.04 cm x 2.375 cm
- 2.24 kg
- Pricing Type
- Build To Plan (BTP)
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 1 year
- Bundled Services
- 1 Year Dell Collect and Return Service
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition + Windows 10 Pro 64-bit Licence
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6200U / 2.3 GHz
- Max Turbo Speed
- 2.8 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 1 TB HDD SATA / 5400 rpm
- Optical Drive
- DVD-Writer
Display
- 15.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 200 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Stereo speakers, microphone
- High Definition Audio
- Audio Features
- Output: MaxxAudio
Input
- Keyboard, touchpad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 4-cell Lithium Ion
- Capacity
- 47 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- USB 3.0 , 2 x USB 2.0 , VGA , Headphone/microphone combo jack , LAN
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial), McAfee (30 days trial), Windows 10 Pro 64-bit recovery DVD
- Black
- Included Accessories
- Power adapter
- Pricing Type
- 2.24 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- Bundled Services
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
