Dell UZ2315H 23" 1920x1080 VGA HDMI DisplayPort IPS USB Monitor
Quicklinx: 9HTRWS00 Mfr#: 859-BBDD
With the Dell UltraSharp 23 multimedia monitor, you get a complete multimedia configuration that makes it easy to collaborate with colleagues and improve productivity.
Made with premium-quality materials, the UZ2315H has BFR/PVC-free laminates in its circuit boards and has arsenic-free glass and a mercury-free LED panel. The chassis is made of more than 25 percent post-consumer recycled plastics.
  • Connect with Full HD multimedia
  • Boost productivity with adjustable viewing
    Modify your monitor to fit the way you work for more flexible viewing, plus comprehensive digital connectivity.
  • Count on reliability and eco-efficiency
Dell UltraSharp UZ2315H - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Camera, microphone, 2.0 megapixel camera, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.8 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
2xHDMI, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 90 - 264 V (50/60 Hz)
56.38 cm x 18 cm x 37.69 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC, DDC/CI, RoHS
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue, aspect control, off timer
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Sync on Green, Mobile High-Definition Link (MHL), PowerNap, stand lock, Energy Gauge, Energy Saver
56.38 cm x 18 cm x 37.69 cm - with stand
Audio
Speakers - integrated
Output Power / Channel
3 Watt
Input
Camera, microphone
VGA , 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphone/microphone combo jack (mini-jack)
Mechanical
Tilt Angle
-5.5/+22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
125 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
19 W
Power Consumption (Typical)
60 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption Sleep
1.2 Watt
On / Off Switch
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 56.38 cm - depth: 18 cm - height: 37.69 cm , Without stand - width: 56.38 cm - depth: 4.46 cm - height: 36.1 cm - weight: 3.5 kg
Sustainability Information
ENERGY STAR Certified
10 - 80% (non-condensing)
9HTR C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
