With the Dell UltraSharp 23 multimedia monitor, you get a complete multimedia configuration that makes it easy to collaborate with colleagues and improve productivity.
Made with premium-quality materials, the UZ2315H has BFR/PVC-free laminates in its circuit boards and has arsenic-free glass and a mercury-free LED panel. The chassis is made of more than 25 percent post-consumer recycled plastics.
Connect with Full HD multimedia
With the Dell UltraSharp 23 multimedia monitor, you get a complete multimedia configuration that makes it easy to collaborate with colleagues and improve productivity. -
Boost productivity with adjustable viewing
Modify your monitor to fit the way you work for more flexible viewing, plus comprehensive digital connectivity. -
Count on reliability and eco-efficiency
- Dell UltraSharp UZ2315H - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 28 kWh
- Power Consumption (On mode)
- 19 W
- Camera, microphone, 2.0 megapixel camera, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 72% (CIE 1931), 83% (CIE 1976)
- Input Connectors
- 2xHDMI, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 90 - 264 V (50/60 Hz)
- 56.38 cm x 18 cm x 37.69 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC, DDC/CI, RoHS
- Display Type
- Energy Class
- Class A
- 28 kWh
- Diagonal Size
- 23"
- Built-in Devices
- 2.0 megapixel camera, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 5000K, 6500K, 7500K, 10000K, 5700K
- Controls & Adjustments
- Mute, volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue, aspect control, off timer
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Sync on Green, Mobile High-Definition Link (MHL), PowerNap, stand lock, Energy Gauge, Energy Saver
- 56.38 cm x 18 cm x 37.69 cm - with stand
Audio
- Speakers - integrated
- Output Power / Channel
- 3 Watt
Input
- VGA , 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphone/microphone combo jack (mini-jack)
Mechanical
- Tilt Angle
- -5.5/+22
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 125 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Included Accessories
- Stand
- Cables Included
- 1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 19 W
- Power Consumption (Typical)
- 60 Watt
- Power Consumption Stand by
- 1.2 Watt
- Power Consumption Sleep
- 1.2 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 56.38 cm - depth: 18 cm - height: 37.69 cm , Without stand - width: 56.38 cm - depth: 4.46 cm - height: 36.1 cm - weight: 3.5 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
