Dell UZ2315H 23" 1920x1080 8ms VGA HDMI DisplayPort USB IPS LED Monitor
Quicklinx: BJ4QWS00 Mfr#: 210-AEVM
With the Dell UltraSharp 23 multimedia monitor, you get a complete multimedia configuration that makes it easy to collaborate with colleagues and improve productivity.
Made with premium-quality materials, the UZ2315H has BFR/PVC-free laminates in its circuit boards and has arsenic-free glass and a mercury-free LED panel. The chassis is made of more than 25 percent post-consumer recycled plastics.
  • Connect with Full HD multimedia
  • Boost productivity with adjustable viewing
    Modify your monitor to fit the way you work for more flexible viewing, plus comprehensive digital connectivity.
  • Count on reliability and eco-efficiency
Dell UltraSharp UZ2315H - LED monitor - Full HD (1080p) - 23" - with 3-years Premium Panel Exchange service
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
28 kWh
2.0 megapixel camera, 2 microphones, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 83% (CIE 1976)
Input Connectors
2xHDMI, VGA, 2xMHL, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
56.38 cm x 18 cm x 37.69 cm
5.33 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, RoHS
3-year warranty
Bundled with
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, gamma correction, input select, colour temperature, phase, clock, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Ultra wide viewing angle, PowerNap, stand lock, Energy Gauge, Energy Saver, Transition Minimised Differential Signaling (TMDS) technology
56.38 cm x 18 cm x 37.69 cm - with stand
5.33 kg
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , 2 x MHL / HDMI , DisplayPort , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphone/microphone combo jack
Mechanical
Tilt Angle
-5.5/+22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
125 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management
Stand
1 x power adapter , 1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
United Kingdom
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
25 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption Sleep
1.2 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 56.38 cm - depth: 4.46 cm - height: 36.1 cm - weight: 3.5 kg , With stand - width: 56.38 cm - depth: 18 cm - height: 37.69 cm - weight: 5.33 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BJ4Q C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
