Your basket is empty
Dell UZ2315H 23" 1920x1080 8ms VGA HDMI DisplayPort USB IPS LED Monitor
Quicklinx: BJ4QWS00 Mfr#: 210-AEVM
With the Dell UltraSharp 23 multimedia monitor, you get a complete multimedia configuration that makes it easy to collaborate with colleagues and improve productivity.
Made with premium-quality materials, the UZ2315H has BFR/PVC-free laminates in its circuit boards and has arsenic-free glass and a mercury-free LED panel. The chassis is made of more than 25 percent post-consumer recycled plastics.
Dell UltraSharp UZ2315H - LED monitor - Full HD (1080p) - 23" - with 3-years Premium Panel Exchange service
LED-backlit LCD monitor - 23"
Energy Class
Class A
Energy Consumption per Year
28 kWh
2.0 megapixel camera, 2 microphones, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, VGA, 2xMHL, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
56.38 cm x 18 cm x 37.69 cm
5.33 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, RoHS, TCO Displays
3 years warranty
Bundled with
Display Type
Energy Class
Class A
28 kWh
Diagonal Size
23"
Viewable Size
23"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, gamma correction, input select, colour temperature, phase, clock, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, 83% (CIE 1976) colour gamut, ultra wide viewing angle, PowerNap, stand lock, Energy Gauge, Energy Saver, Transition Minimised Differential Signaling (TMDS) technology
56.38 cm x 18 cm x 37.69 cm - with stand
5.33 kg
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , 2 x MHL / HDMI , DisplayPort , 2 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Headphone/microphone combo jack
Mechanical
Tilt Angle
- 5.5/+22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
125 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management
Stand
1 x power adapter , 1 x HDMI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
United Kingdom
25 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption Sleep
1.2 Watt
Included Software
Drivers & Utilities
Dimensions & Weight Details
Without stand - width: 56.38 cm - depth: 4.46 cm - height: 36.1 cm - weight: 3.5 kg , With stand - width: 56.38 cm - depth: 18 cm - height: 37.69 cm - weight: 5.33 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BJ4Q C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BJ4Q C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
BJ4Q C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
BJ4Q C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
BJ4Q C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
BJ4Q C2G Pro HDMI to VGA Converter In Stock £46.35
BJ4Q C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
