Brand
Dell Universal Dock D6000 - UK
Quicklinx: D2KXWS00 Mfr#: DELL-D6000
Conveniently dock any laptop, equipped with USB-C or USB 3.0 ports with the Dell universal dock - D6000. You'll be able to connect up to three 4K displays simultaneously. A single USB-C cable connection allows you to transfer audio, video, data and power - enabling a fast and convenient docking experience. It also eliminates the need for an additional power adapter, keeping your desk neat and tidy.
  • Conveniently connect any laptop, equipped with USB-C or USB 3.0
    Enjoy universal compatibility with a wide range of PC brands and operating systems, supported by DisplayLink technology. Whether you're at your desk or in a shared workspace, you can easily connect to displays, a mouse, keyboard and audio devices from your compatible system of choice.
  • Connect up to three 4K displays simultaneously
    With plug and play, connecting to the dock is fast and convenient. Plug in a single USB-C cable and transfer audio, video, data and power. Plus, the single cable eliminates the need for an additional power adapter, keeping your workspace clean and clutter-free.
Dell Universal Dock - D6000 - docking station - USB - GigE
Docking station
Docking Interface
USB
7.8 cm x 16.8 cm x 3 cm
380 g
Gigabit Ethernet
Power adapter 130 Watt
Inspiron 3780; Latitude 5320, 5520, 7390 2-in-1, 7400 2-in-1; Vostro 5390, 5391; XPS 13 9310, 13 9380
Docking station
7.8 cm
16.8 cm
3 cm
380 g
Enclosure Colour
Gigabit Ethernet
1 x SuperSpeed USB 3.0 , 1 x USB-C , 1 x display / video - HDMI , 2 x display / video - DisplayPort , 1 x USB host , 3 x SuperSpeed USB 3.0 , 1 x SuperSpeed USB 3.0 with PowerShare , 1 x USB-C with PowerShare , 1 x headphones / speakers , 1 x network
1 x USB-C cable , 1 x USB adapter
Security Slot Type
Kensington security slot
Power adapter
Power Provided
130 Watt
Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
Dell Inspiron 3780 , Dell Latitude 5320, 5520, 7390 2-in-1, 7400 2-in-1 , Dell Vostro 5390, 5391 , Dell XPS 13 9310, 13 9380
