Dell UltraSharp UP3216Q 31.5" 3840x2160 6ms HDMI DisplayPort USB IPS LED Monitor
Quicklinx: BR9ZWS00 Mfr#: 210-AGUO
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 6ms
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
Hurry, only 1 left in stock!
£1,053.56 ex VAT
£1,264.27 inc VAT
See your work in beautiful Ultra HD 4K resolution on the large Dell UltraSharp monitor with PremierColor for exceptional color accuracy and professional standards.
  • Accurate, consistent color
    With PremierColor, your monitor provides superb color precision with four color spaces, including 99.5% Adobe RGB, 100% sRGB, 100% REC709 and 87% DCI-P3 coverage - ideal to suit every color professional's needs.
  • Phenomenal viewing experience
    Enjoy every little detail with 3840 x 2160 Ultra HD 4K resolution. That's four times the resolution of Full HD.
Dell UltraSharp UP3216Q - LED monitor - 32" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 32"
Energy Class
Class C
Energy Consumption per Year
85 kWh
USB 3.0 hub, SD/MS/MMC card reader
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.182 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
HDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
74.99 cm x 21.4 cm x 48.26 cm
11.2 kg
Plug and Play, VESA EDID, DDC/CI, RoHS, TCO Displays
3-year warranty
Bundled with
Display Type
Energy Class
Class C
85 kWh
Diagonal Size
32"
Viewable Size
31.5"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.182 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
24 - 75 Hz
Horizontal Refresh Rate
30 - 140 kHz
Video Bandwidth
533.25 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, uniformity, hue, aspect control, colour space, gain, offset
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Picture by picture, PremierColor technology, LED edgelight system, 100% sRGB colour gamut, Picture-in-Picture Plus, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Premium Panel Guarantee, 99.5% Adobe RGB colour gamut, arsenic-free glass, Factory Calibration Report, 100% Rec 709 colour gamut, 87% DCI-P3
74.99 cm x 21.4 cm x 48.26 cm - with stand
11.2 kg
Bundled with
DisplayPort , Mini DisplayPort , MHL / HDMI , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B) , Audio line-out
Mechanical
Tilt Angle
- 5.5/+22
Swivel Angle
60
Height Adjustment
90 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
Stand, cable management cover
1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x Mobile High-Definition Link (MHL)-HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
130 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Display drivers, Dell Display Manager
Dimensions & Weight Details
With stand - width: 74.99 cm - depth: 21.4 cm - height: 48.26 cm - weight: 11.2 kg , Without stand - width: 74.99 cm - depth: 5.15 cm - height: 44.46 cm - weight: 8.6 kg
Limited warranty - 3 years
35 °C
10 - 80% (non-condensing)
BR9Z C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BR9Z C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.37
BR9Z C2G 5m Select High Speed HDMI with Ethernet In Stock £21.26
BR9Z C2G 10m Select High Speed HDMI with Ethernet In Stock £40.83
BR9Z C2G 15m Select High Speed HDMI with Ethernet In Stock £55.31
BR9Z C2G Pro HDMI to VGA Converter In Stock £50.99
BR9Z C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 32in
Response Time: 6ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Dell
Price Range Ex VAT: 1000 - 1500
