Dell UltraSharp UP2716D 27" 2560x1440 6ms HDMI DisplayPort USB IPS LED Monitor
Quicklinx: BR9YWS00 Mfr#: 210-AGTU
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 6ms
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
More than 50 in stock
£514.03 ex VAT
£616.83 inc VAT
Expect vivid, accurate color precision, ultrathin bezels and wide color coverage to suit your professional needs with the Dell UltraSharp monitor.
Dell UltraSharp UP2716D - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
66 kWh
Power Consumption (On mode)
45 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
61.14 cm x 20.03 cm x 41.03 cm
7.11 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
TCO Certified Displays 8
Plug and Play, VESA EDID, DDC/CI, RoHS
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class C
66 kWh
45 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 88 kHz
Video Bandwidth
241.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, hue, aspect control, colour space, gain, offset
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Picture in picture, picture by picture, PremierColor technology, 100% Adobe RGB colour gamut, 100% sRGB colour gamut, stand lock, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Premium Panel Guarantee, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass, Factory Calibration Report, 98% DCI-P3, 100% Rec 709 colour gamut
61.14 cm x 20.03 cm x 41.03 cm - with stand
7.11 kg
DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , 4 x USB 3.0 downstream (Type A) , 2 x USB 3.0 upstream (Type B) , DisplayPort output , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
Stand
1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
130 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 61.14 cm - depth: 20.03 cm - height: 41.03 cm - weight: 7.11 kg , Without stand - width: 61.14 cm - depth: 5.14 cm - height: 36.25 cm - weight: 4.56 kg
TCO Certified
Limited warranty - 3 years
Bundled Services
35 °C
10 - 80% (non-condensing)
Dell UltraSharp UP2716D 27 Bundle deal on Dell UltraSharp UP2716D 27" 2560x1440 6ms HDMI DisplayPort USB IPS LED Monitor
£613.20
BR9Y C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BR9Y C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.66
BR9Y C2G 5m Select High Speed HDMI with Ethernet In Stock £22.28
BR9Y C2G 10m Select High Speed HDMI with Ethernet In Stock £42.77
BR9Y C2G 15m Select High Speed HDMI with Ethernet In Stock £57.94
BR9Y C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 27in
Response Time: 6ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Dell
Price Range Ex VAT: 500 - 750
