Dell UltraSharp UP2516D 25" 2560x1440 6ms HDMI DisplayPort USB IPS LED Monitor
Quicklinx: BR9XWS00 Mfr#: 210-AGTW
Expect vivid, accurate color precision, ultrathin bezels and the widest color coverage to suit your professional needs with the Dell UltraSharp 25 monitor with PremierColor.
  • Ideal color coverage
    Enjoy exceptional color accuracy and consistency right out of the box with an extremely precise Delta-E < 2 factory calibration. The UP2516D monitor with PremierColor offers wide coverage of industry color standards with four color spaces, plus user-enabled color customization.
  • Outstanding view
    Experience seamless dual or multi-monitor setup with ultrathin bezels. You can count on beautiful clarity with QHD resolution, plus consistent color across and ultrawide viewing angles.
Dell UltraSharp UP2516D - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class C
Energy Consumption per Year
71 kWh
Power Consumption (On mode)
48 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.216 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Colour Gamut
100% Rec 709, 100% sRGB, 98% DCI-P3, 99% Adobe RGB
Input Connectors
2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
56.77 cm x 20.03 cm x 39.8 cm
6.65 kg
Microsoft Certification
Compatible with Windows 7
Plug and Play, DDC/CI, RoHS, BC1.2
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class C
71 kWh
Diagonal Size
25"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.216 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 88 kHz
Video Bandwidth
241.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, hue, aspect control, colour space, gain, offset
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Picture in picture, picture by picture, PremierColor technology, stand lock, Multi-Stream transport (MST), adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Premium Panel Guarantee, arsenic-free glass, Factory Calibration Report
56.77 cm x 20.03 cm x 39.8 cm - with stand
6.65 kg
DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , 4 x USB 3.0 downstream (Type A) , 2 x USB 3.0 upstream (Type B) , DisplayPort output , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
48 W
Power Consumption (Typical)
130 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 56.77 cm - depth: 20.03 cm - height: 39.8 cm - weight: 6.65 kg , Without stand - width: 56.77 cm - depth: 5.16 cm - height: 33.79 cm - weight: 4.1 kg
Limited warranty - 3 years
Bundled Services
35 °C
10 - 80% (non-condensing)
BR9X C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
