Expect vivid, accurate color precision, ultrathin bezels and the widest color coverage to suit your professional needs with the Dell UltraSharp 25 monitor with PremierColor.
Ideal color coverage
Enjoy exceptional color accuracy and consistency right out of the box with an extremely precise Delta-E < 2 factory calibration. The UP2516D monitor with PremierColor offers wide coverage of industry color standards with four color spaces, plus user-enabled color customization. -
Outstanding view
Experience seamless dual or multi-monitor setup with ultrathin bezels. You can count on beautiful clarity with QHD resolution, plus consistent color across and ultrawide viewing angles.
- Dell UltraSharp UP2516D - LED monitor - 25"
- LED-backlit LCD monitor - 25"
- Energy Class
- Class C
- Energy Consumption per Year
- 71 kWh
- Power Consumption (On mode)
- 48 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.216 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% Rec 709, 100% sRGB, 98% DCI-P3, 99% Adobe RGB
- Input Connectors
- 2xHDMI (MHL), DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.77 cm x 20.03 cm x 39.8 cm
- 6.65 kg
- Microsoft Certification
- Compatible with Windows 7
- Plug and Play, DDC/CI, RoHS, BC1.2
- 3-year warranty
- Bundled Services
- 3 years Advanced Exchange Service
- Display Type
- Energy Class
- Class C
- 71 kWh
- Diagonal Size
- 25"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.216 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 6 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 88 kHz
- Video Bandwidth
- 241.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 10000K
- Controls & Adjustments
- Brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, hue, aspect control, colour space, gain, offset
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Picture in picture, picture by picture, PremierColor technology, stand lock, Multi-Stream transport (MST), adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Premium Panel Guarantee, arsenic-free glass, Factory Calibration Report
- Black
- 56.77 cm x 20.03 cm x 39.8 cm - with stand
- 6.65 kg
- DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , 4 x USB 3.0 downstream (Type A) , 2 x USB 3.0 upstream (Type B) , DisplayPort output , Audio line-out
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
- Cables Included
- 1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- 48 W
- Power Consumption (Typical)
- 130 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 56.77 cm - depth: 20.03 cm - height: 39.8 cm - weight: 6.65 kg , Without stand - width: 56.77 cm - depth: 5.16 cm - height: 33.79 cm - weight: 4.1 kg
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
