Dell UltraSharp U4919DW 49" 5120x1440 5ms HDMI DisplayPort USB-C Curved Monitor
Quicklinx: FJ3WWS00 Mfr#: DELL-U4919DW
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 5ms
Speakers: None
Interfaces: HDMI, DisplayPort, USB-C
£915.83 ex VAT
£1,098.99 inc VAT
The 49-inch curved dual QHD monitor with the revolutionary ultra-wide 32:9 aspect ratio for seamless multi-screen productivity. Delivering an immersive experience, this expansive monitor is the ideal replacement for two 27-inch QHD monitors. The large onscreen space with 5120 x 1440 resolution and IPS technology allows users to view more content and see fine details with consistent color across a wide viewing angle.
Dell UltraSharp U4919DW - LED monitor - curved - 49"
LED-backlit LCD monitor - 49"
Energy Class
Class G
Energy Consumption per Year
74 kWh
Power Consumption (On mode)
47 W
Curved Screen
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
32:9
Native Resolution
Dual Quad HD 5120 x 1440 at 60 Hz
Pixel Pitch
0.234 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
1.07 billion colours
Colour Gamut
99% sRGB
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
121.51 cm x 25.26 cm x 45.86 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
DisplayPort 1.4, HDCP 2.2
Bundled Services
3 years Advanced Exchange Service
OptiPlex 3090; Precision 7560; XPS 15 9570
Display Type
Energy Class
Class G
74 kWh
Diagonal Size
49"
Curved Screen
Yes (3800R)
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
32:9
Native Resolution
Pixel Pitch
0.234 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
99% sRGB
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Picture by picture, 10-bit gamma, LED edgelight system, Delta E<2 calibration
121.51 cm x 25.26 cm x 45.86 cm - with stand
2 x HDMI (HDCP) , DisplayPort (HDCP) , 2 x USB 3.0 upstream , 5 x USB 3.0 downstream , USB-C/DisplayPort 1.4 Alt Mode
Mechanical
Tilt Angle
-5/+21
Swivel Angle
340
Height Adjustment
90 mm
VESA Mounting Interface
Input Voltage
47 W
47 kWh/1000h
Power Consumption (Typical)
60 Watt
Power Consumption (Max)
230 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption (Off Mode)
0.2 Watt
On / Off Switch
No
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 121.51 cm , Without stand - width: 121.51 cm - height: 37.1 cm - weight: 11.4 kg
Shipping Weight
26.43 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
Bundled Services
20 - 80% (non-condensing)
Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 15 9570
FJ3W Dell Docking Station WD19S - USB-C - HDMI, 2 x DP, USB-C - GigE In Stock £163.47
FJ3W Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £33.58
FJ3W Dell SB521A Magnetic Sound bar In Stock £35.35
FJ3W Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £45.51
Diagonal Size: 49in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: DisplayPort
Interfaces: USB-C
Brand: Dell
Price Range Ex VAT: £750 - £1000
