The 49-inch curved dual QHD monitor with the revolutionary ultra-wide 32:9 aspect ratio for seamless multi-screen productivity. Delivering an immersive experience, this expansive monitor is the ideal replacement for two 27-inch QHD monitors. The large onscreen space with 5120 x 1440 resolution and IPS technology allows users to view more content and see fine details with consistent color across a wide viewing angle.
- Dell UltraSharp U4919DW - LED monitor - curved - 49"
- LED-backlit LCD monitor - 49"
- Energy Class
- Class G
- Energy Consumption per Year
- 74 kWh
- Power Consumption (On mode)
- 47 W
- Curved Screen
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 32:9
- Native Resolution
- Dual Quad HD 5120 x 1440 at 60 Hz
- Pixel Pitch
- 0.234 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- 121.51 cm x 25.26 cm x 45.86 cm
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- DisplayPort 1.4, HDCP 2.2
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- OptiPlex 3090; Precision 7560; XPS 15 9570
- Display Type
- Energy Class
- Class G
- 74 kWh
- Diagonal Size
- 49"
- Curved Screen
- Yes (3800R)
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 32:9
- Native Resolution
- Pixel Pitch
- 0.234 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Picture by picture, 10-bit gamma, LED edgelight system, Delta E<2 calibration
- 121.51 cm x 25.26 cm x 45.86 cm - with stand
- 2 x HDMI (HDCP) , DisplayPort (HDCP) , 2 x USB 3.0 upstream , 5 x USB 3.0 downstream , USB-C/DisplayPort 1.4 Alt Mode
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 340
- Height Adjustment
- 90 mm
- VESA Mounting Interface
- Input Voltage
- 47 W
- Power Consumption SDR (On mode)
- 47 kWh/1000h
- Power Consumption (Typical)
- 60 Watt
- Power Consumption (Max)
- 230 Watt
- Power Consumption Stand by
- 0.4 Watt
- 0.2 Watt
- On / Off Switch
- No
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 121.51 cm , Without stand - width: 121.51 cm - height: 37.1 cm - weight: 11.4 kg
- Shipping Weight
- 26.43 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- Bundled Services
- 20 - 80% (non-condensing)
- Designed For
- Dell OptiPlex 3090 , Dell Precision 7560 , Dell XPS 15 9570
