Streamline your work by viewing content from up to four PCs. A height adjustable stand and USB-C connectivity maximize comfort and productivity.
More ways to see it all
Picture-by-Picture (PBP) enables a comprehensive view of your work by displaying content from up to four different PCs onto one screen. -
Exceptional details
The 4K UHD resolution and a high pixel density of 103ppi shows your work in striking clarity. -
Outstanding color
Experience smooth color gradation and precision across more shades with a high color depth of 1.07 billion colors. -
The space to perform
Save valuable desk space thanks to the small monitor base. -
More accessible
Conveniently placed USB ports are located at the side of the monitor for quick connectivity. -
Collaboration made easy
HDMI-CEC enables convenient supportability with key Zoom Room features, like scheduling operating hours and manual on/off.
- Dell UltraSharp U4320Q - LED monitor - 4K - 42.5"
- LED-backlit LCD monitor - 42.5"
- Energy Class
- Class G
- Energy Consumption per Year
- 98 kWh
- Power Consumption (On mode)
- 64.3 W
- USB 3.1 Gen 1/USB-C hub, USB PD 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.06 billion colours
- Colour Gamut
- 96% sRGB
- Input Connectors
- 2xHDMI, 2xDisplayPort, USB-C
- Height, swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 96.72 cm x 24.9 cm x 59.52 cm
- 17.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- RoHS, NFPA 99, BFR-free, DisplayPort 1.4, PVC-free, Mercury-free
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510
- Display Type
- Energy Class
- Class G
- 98 kWh
- Diagonal Size
- 42.5"
- Built-in Devices
- USB Power Delivery
- 90 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2451 mm
- Pixel Per Inch
- 103.23
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 96% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Black
- 96.72 cm x 24.9 cm x 59.52 cm - with stand
- 17.6 kg
- 2 x HDMI , 2 x DisplayPort 1.4 , USB-C upstream/DisplayPort Alt Mode with Power Delivery (power up to 90W) , Audio line-out (mini-jack) , 2 x USB 3.1 Gen 1 downstream , USB 3.1 downstream with Battery Charging 1.2 , USB-C 3.1 downstream
Mechanical
- Tilt Angle
- -5/+10
- Swivel Angle
- 40
- Height Adjustment
- 60 mm
- VESA Mounting Interface
- 100 x 100 mm, 200 x 200 mm
- Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
- Cables Included
- 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C to USB-C cable , 1 x USB-C to USB-A cable
- Input Voltage
- 64.3 W
- Power Consumption SDR (On mode)
- 64.3 kWh/1000h
- Power Consumption (Typical)
- 75 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 96.72 cm - depth: 24.9 cm - height: 59.52 cm - weight: 17.6 kg , Without stand - width: 96.72 cm - depth: 5.9 cm - height: 56.44 cm - weight: 13.2 kg
- Shipping Weight
- 25.6 kg
- ENERGY STAR Certified
- Bundled Services
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
