Dell UltraSharp U4320Q  LED  42.5" 3840X2160 4K HDMI USB-C
Quicklinx: G0KZWS00 Mfr#: DELL-U4320Q
Diagonal Size: 42.5in
Max Resolution: 3840 x 2160
Response Time: 5ms
Interfaces: DisplayPort, USB-C, HDMI
£694.02 ex VAT
£832.82 inc VAT
Streamline your work by viewing content from up to four PCs. A height adjustable stand and USB-C connectivity maximize comfort and productivity.
  • More ways to see it all
    Picture-by-Picture (PBP) enables a comprehensive view of your work by displaying content from up to four different PCs onto one screen.
  • Exceptional details
    The 4K UHD resolution and a high pixel density of 103ppi shows your work in striking clarity.
  • Outstanding color
    Experience smooth color gradation and precision across more shades with a high color depth of 1.07 billion colors.
  • The space to perform
    Save valuable desk space thanks to the small monitor base.
  • More accessible
    Conveniently placed USB ports are located at the side of the monitor for quick connectivity.
  • Collaboration made easy
    HDMI-CEC enables convenient supportability with key Zoom Room features, like scheduling operating hours and manual on/off.
Dell UltraSharp U4320Q - LED monitor - 4K - 42.5"
LED-backlit LCD monitor - 42.5"
Energy Class
Class G
Energy Consumption per Year
98 kWh
Power Consumption (On mode)
64.3 W
USB 3.0 hub, USB PD 90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.2451 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey normal); 5 ms (grey-to-grey fast)
Colour Support
1.06 billion colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
96.72 cm x 24.9 cm x 59.52 cm
17.6 kg
Environmental Standards
ENERGY STAR Qualified
RoHS, NFPA 99, BFR-free, DisplayPort 1.4, PVC-free, Mercury-free
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class G
98 kWh
Diagonal Size
42.5"
Viewable Size
42.5"
Built-in Devices
USB 3.0 hub
USB Power Delivery
90 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2451 mm
Pixel Per Inch
103.23
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
96% sRGB colour gamut
96.72 cm x 24.9 cm x 59.52 cm - with stand
17.6 kg
DisplayPort (DisplayPort 1.4 mode) , 2 x HDMI , USB-C (power up to 90W) , Audio line-out , 2 x USB 3.1 Gen 1 , USB 3.1 downstream with Battery Charging , USB-C downstream
Mechanical
Tilt Angle
-5/+10
Swivel Angle
40
Height Adjustment
60 mm
VESA Mounting Interface
100 x 100 mm, 200 x 200 mm
Security lock slot (cable lock sold separately), VESA interface support, anti-theft protection
1 x USB-C cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C to USB-A cable
Input Voltage
64.3 W
64.3 kWh/1000h
Power Consumption (Typical)
75 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 96.72 cm - depth: 24.9 cm - height: 59.52 cm - weight: 17.6 kg , Without stand - width: 96.72 cm - depth: 5.9 cm - height: 56.44 cm - weight: 13.2 kg
Shipping Weight
25.6 kg
ENERGY STAR Certified
Bundled Services
10 - 90% (non-condensing)
Response Time: 5ms
Interfaces: USB-C
Interfaces: HDMI
Brand: Dell
Price Range Ex VAT: £500 - £750
