- Dell UltraSharp U3421WE - LED monitor - curved - 34.1"
- LED-backlit LCD monitor - 34.1"
- Energy Class
- Class F
- Power Consumption (On mode)
- 31.6 W
- Curved Screen
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- WQHD 3440 x 1440 at 60 Hz
- Pixel Pitch
- 0.2325 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort, USB-C
- Built-in Ethernet
- Height, swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 120/230 V (50/60 Hz)
- 81.36 cm x 23.74 cm x 39.28 cm
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- DisplayPort 1.2, DisplayPort 1.4
- Bundled Services
- 3 years Advanced Exchange Basic Warranty
- Designed For
- Latitude 5320, 5520; Precision 7560; XPS 13 9310, 15 9510
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 34.1"
- Curved Screen
- Yes (1900R)
- Built-in Devices
- USB 3.2 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.2325 mm
- Pixel Per Inch
- 109
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 48 - 85 Hz
- Horizontal Refresh Rate
- 30 - 89 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- LED edgelight system
- 81.36 cm x 23.74 cm x 39.28 cm - with stand
Audio
- Speakers - stereo
- Output Power / Channel
- 5 Watt
- 2 x HDMI , DisplayPort 1.4 , USB-C/DisplayPort 1.2 Alt Mode , USB 3.2 Gen 1 upstream (Type B) , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , 2 x USB 3.2 Gen 1 downstream , Audio line-out , Network (RJ-45)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Height Adjustment
- 150 mm
- Cables Included
- 1 x DisplayPort cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable , 1 x HDMI cable - 1.8 m , 1 x USB-C cable - 1.8 m
- Input Voltage
- 31.6 W
- Power Consumption SDR (On mode)
- 31.6 kWh/1000h
- Power Consumption (Typical)
- 36 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 81.36 cm - depth: 23.74 cm - height: 39.28 cm , Without stand - width: 81.36 cm - depth: 5.75 cm - height: 35.91 cm - weight: 7.52 kg
- Shipping Weight
- 16.5 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 5320, 5520 , Dell Precision 7560 , Dell XPS 13 9310, 15 9510
