Dell UltraSharp U3219Q 31.5" 3840x2160 8ms HDMI DisplayPort USB-C IPS LED Monitor
Quicklinx: FFQ8WS00 Mfr#: DELL-U3219Q
12 in stock
£693.87 ex VAT
£832.64 inc VAT
Brilliant color and clarity for your best work. Experience outstanding screen performance on this 31.5" 4K USB-C monitor featuring InfinityEdge and multitasking capabilities.
Dell UltraSharp U3219Q - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
63 kWh
Power Consumption (On mode)
43 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.182 mm
Brightness
400 cd/m²
Contrast Ratio
1300:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
71.25 cm x 22 cm x 46.873 cm
DisplayPort 1.4, HDCP 2.2
3-year warranty
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
XPS 13 9380, 15 9570
Display Type
Energy Class
Class B
63 kWh
43 W
Diagonal Size
32"
Viewable Size
31.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.182 mm
Pixel Per Inch
140
Brightness
400 cd/m²
Contrast Ratio
1300:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
LED edgelight system, 99% sRGB colour gamut, Infinity Edge display, 99% Rec 709 colour gamut, DCI-P3 95% colour gamut
71.25 cm x 22 cm x 46.873 cm - with stand
USB-C upstream/DisplayPort with Power Delivery , HDMI (HDCP) , DisplayPort , 2 x USB 3.0 downstream with Battery Charging 1.2 , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Rotation Angle
180
Height Adjustment
150 mm
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB-C cable , 1 x SuperSpeed USB cable - USB Type A to B
Security Slot Type
Kensington security slot
46 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 71.25 cm - depth: 22 cm - height: 46.873 cm , Without stand - width: 71.25 cm - depth: 4.45 cm - height: 41.45 cm
Limited warranty - 3 years
Bundled Services
Dell XPS 13 9380, 15 9570
Dell UltraSharp U3219Q 31.5 Bundle deal on Dell UltraSharp U3219Q 31.5" 3840x2160 8ms HDMI DisplayPort USB-C IPS LED Monitor
£793.04
Brand: Dell
Price Range Ex VAT: 500 - 750
