Dell UltraSharp U2717D 27" 2560x1440 8ms HDMI LED LCD Monitor
Quicklinx: CLYQWS00 Mfr#: 210-AIDD
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 6ms
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
More than 50 in stock
£276.63 ex VAT
£331.95 inc VAT
The Dell UltraSharp 27 InfinityEdge monitor U2717D takes your view to the edge with less borders.
  • An outstanding viewing experience
    The Dell UltraSharp 27 monitor allows you to see the bigger picture, without boundaries. Perfect for industry professionals looking to get the most out of their desktop experience.
  • Optimize your view
    Feast your eyes on extremely thin borders to ever to grace all four sides of a monitor. Dell's InfinityEdge borders, which include the bezel width and inactive space, create an almost seamless viewing experience.
  • A more accurate display
    Colors stay as precise as they can be to give you a more immersive display. And with the factory color calibration report, you're guaranteed that every monitor has a 99% sRGB coverage at deltaE <2 - ensuring every color is as accurate.
  • Stunning at every angle
    Colors remain consistent across an ultrawide viewing angle, guaranteeing a dazzling display no matter how you view it.
  • Witness the difference
    See more with 1.77 times the screen details on QHD resolution than Full HD.
  • Designed with you in mind
    Quickly adjust your monitor to comfortably fit the way you work.
  • Vividly clear
    Immerse yourself in cohesive multi-monitor view with super thin black borders and the thinnest bezel width to date in between two displays on all sides.
  • Unmatched versatility
    Enjoy full adjustability to pivot, tilt, and swivel your monitor to the position and height you desire. And with HDMI 1.4 (MHL 2.0), DP 1.2, mini-DP 1.2, DP-out, 4 USB 3.0, and audio line-out ports, connecting to all your peripherals at once is both easy and convenient.
Dell UltraSharp U2717D - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (typical); 6 ms (fast)
Colour Support
16.7 million colours
Input Connectors
HDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
61.13 cm x 20.03 cm x 41.02 cm
7 kg
Environmental Standards
TCO Certified ENERGY STAR Qualified
Plug and Play, VESA EDID, FCC, DDC/CI, RoHS
3-year warranty
Bundled Services
3 years Advanced Exchange Basic Warranty
Display Type
Energy Class
Class A
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
30 - 88 kHz
Video Bandwidth
241.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
LED edgelight system, Mobile High-Definition Link (MHL), stand lock, 99% sRGB colour gamut
61.13 cm x 20.03 cm x 41.02 cm - with stand
7 kg
MHL / HDMI , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand
1 x USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Security Slot Type
Kensington security slot
74 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 61.13 cm - depth: 20.03 cm - height: 41.02 cm - weight: 7 kg , Without stand - width: 61.13 cm - depth: 4.83 cm - height: 35.56 cm - weight: 4.5 kg
ENERGY STAR Certified
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
Dell UltraSharp U2717D 27 Bundle deal on Dell UltraSharp U2717D 27" 2560x1440 8ms HDMI LED LCD Monitor
£375.80
Diagonal Size: 27in
Response Time: 6ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Dell
Price Range Ex VAT: 150 - 300
