Dell UltraSharp U2715H  U 27" 2560 x 1440 LED Backlit
Quicklinx: FPYMWS00 Mfr#: DELL-U2719DC
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, USB-C
£329.59 ex VAT
£395.50 inc VAT
Designed for performance. See fine details and true-to-life color on this 27" QHD monitor in an innovative, stylishly thin design with USB-C connectivity.
Dell UltraSharp U2719DC - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
27 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
61.2 cm x 18 cm x 52 cm
8.72 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
RoHS, NFPA 99, DisplayPort 1.4, HDCP 1.4
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Latitude 7400 2-in-1; XPS 13 9380, 15 9570
Display Type
Energy Class
Class A
40 kWh
27 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
BFR/PVC-free, 99.9% sRGB colour gamut, arsenic-free glass, 99% Rec 709 colour gamut, 85% DCI-P3
61.2 cm x 18 cm x 52 cm - with stand
8.72 kg
DisplayPort , DisplayPort output (MST) , HDMI (HDCP) , 2 x USB 3.0 downstream , 2 x USB 3.0 downstream with Battery Charging 1.2 , USB-C , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
80
Height Adjustment
130 mm
VESA Mounting Interface
Security lock slot (cable lock sold separately), LED indicator, VESA interface support, anti-theft stand lock slot
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x USB-C cable - USB-C , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
33.2 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 61.2 cm - depth: 18 cm - height: 52 cm - weight: 8.72 kg , Without stand - width: 61.22 cm - depth: 3.9 cm - height: 35.5 cm - weight: 4.19 kg
TCO Certified
ENERGY STAR Certified
Bundled Services
10 - 80% (non-condensing)
Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: FPYM 043689
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £189.63
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 27in
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: USB-C
Brand: Dell
Stock Status: Used Stock
Price Range Ex VAT: 300 - 500
