Dell Ultrasharp U2518D 25" 2560x1440 8ms HDMI DisplayPort IPS LED Monitor
Quicklinx: DMR6WS00 Mfr#: DELL-U2518D
Diagonal Size: 25in
Max Resolution: 2560 x 1440
Response Time: 5ms
Interfaces: DisplayPort, HDMI, Mini DisplayPort
More than 50 in stock
£222.51 ex VAT
£267.01 inc VAT
Discover ultimate efficiency with a 25" screen featuring incredibly thin bezels, ideal for a multiple monitor setup.
Dell High Dynamic Range (HDR) projects images with striking depth, captivating your attention and giving each job a gorgeous finish.
Multitask in comfort on this device with a fully adjustable stand, Dell Display Manager and ComfortView.
  • See the whole picture
    With the UltraSharp monitor you get more than a pretty picture - it's a gorgeous screen made for multitasking.
  • Broaden your horizons
    The expansive 25" screen features InfinityEdge, a virtually borderless display on all four sides that lets you see more of your work.
  • Multiply your productivity
    Hone in on your work with a multi-monitor setup. With seamless bezels and DisplayPort connectivity, using multiple monitors has never been easier.
  • Enjoy the details
    View clear images with QHD (2560x1440) resolution - nearly twice as crisp as Full HD displays. With excellent color consistency across a wide 178°/178° viewing angle, you can easily work and collaborate.
  • A captivating sight
    Dell HDR combines greater depth of colors, remarkable clarity and a high contrast range of shades to create strikingly realistic images.
  • Color consistency comes standard
    The UltraSharp monitor is factory-calibrated at 99% sRGB for precise hues right out of the box. Each monitor features a factory calibration report that guarantees color correctness.
  • Uncompromised images
    View your HDR10 content like it was meant to be seen. Even your HDR photos will boast a lifelike experience.
  • Multitasking made easy
    Tackle multiple tasks at once thanks to a multi-monitor setup with DisplayPort connectivity.
  • Designed with you in mind
    Customize your view with a fully adjustable stand that tilts, swivels and rotates 90 degrees clockwise or counter clockwise.
  • Easy on the eyes
    This monitor has a flicker-free screen with ComfortView, a feature that filters out harmful blue light emissions to optimize eye comfort.
Dell UltraSharp U2518D - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class B
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
56.76 cm x 20.01 cm x 39.72 cm
5.89 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, RoHS, TCO Displays, BFR-free
Latitude 7400 2-in-1; XPS 13 9380, 15 9570, 15 9575 2-in-1
Display Type
Energy Class
Class B
44 kWh
30 W
Diagonal Size
25"
Viewable Size
25"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.216 mm
Pixel Per Inch
117.5
Brightness
350 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 140 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Mercury free, Flicker-Less technology, arsenic-free glass, Wide Viewing Angle
56.76 cm x 20.01 cm x 39.72 cm - with stand
5.89 kg
USB 3.0 upstream , 2 x USB 3.0 downstream , 2 x USB 3.0 downstream with Power Charging , DisplayPort , Mini DisplayPort , HDMI , DisplayPort output , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), PVC free, anti-theft stand lock slot
1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Security Slot Type
Kensington security slot
30 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Included Software
Dimensions & Weight Details
With stand - width: 56.76 cm - depth: 20.01 cm - height: 39.72 cm - weight: 5.89 kg , Without stand - width: 56.76 cm - depth: 4.92 cm - height: 33.15 cm - weight: 3.42 kg
ENERGY STAR Certified
10 - 80% (non-condensing)
Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570, 15 9575 2-in-1
Dell Ultrasharp U2518D 25 Bundle deal on Dell Ultrasharp U2518D 25" 2560x1440 8ms HDMI DisplayPort IPS LED Monitor
£321.68
Diagonal Size: 25in
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Dell
Price Range Ex VAT: 150 - 300
