Dell UltraSharp U2515H 25" 2560x1440 8ms HDMI DP USB 2K Monitor
Quicklinx: B15XWS00 Mfr#: 210-ADZM
Bring your work to life in vivid color detail, sharp QHD resolution and extensive connectivity for outstanding usability. Superior screen clarity meets complete color precision for a brilliant viewing experience.
Work the way you want. Position your monitor for ultimate comfort with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals.
Made with eco-friendly materials, the U2515H is BFR/PVC-free (excluding external cables) and has arsenic-free glass and a mercury-free LED panel.
  • A performance to remember
    Enjoy 25" of superb screen clarity on a sharp QHD 2560 x 1440 resolution monitor. Plus, you get great color consistency across an ultra-wide 178°/178° viewing angle. Get exceptional color accuracy and consistency right out of the box, with each monitor factory tuned at 99% sRGB with a deltaE <3. Help boost your productivity with a dual or multi-monitor setup and take advantage of the ultra-thin bezel that is ideal for a seamless, virtually borderless viewing between monitors. Easy Arrange lets you choose how you view your custom window layout.
  • Designed for your comfort and convenience
    Smoothly pivot 90° clockwise or counter-clockwise, placing the thinnest edges side-by-side for an enhanced viewing experience, especially ideal for dual or multi-monitor set up. The U2515H is VESA-compatible, so you can wall mount your monitor. For convenient connections to other devices in your workspace, the U2515H provides two HDMI (MHL) ports, a DisplayPort, a mini-DisplayPort and five USB 3.0 ports. Quickly charge BC1.2 compatible and other USB devices with a USB 3.01 port found on the rear of the monitor that supplies high-speed charging and powering.
  • Reliable and eco-efficient
    Your Dell UltraSharp 25 monitor - U2515H is designed to be pixel perfect.
  • Environmentally-conscious design
    Made with eco-friendly materials, the U2515H is BFR/PVC-free (excluding external cables) and has arsenic-free glass and a mercury-free LED panel. Enhanced power management with PowerNap enables the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
Dell UltraSharp U2515H - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class B
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms (grey-to-grey), 19 ms (On/Off)
Colour Support
16.8 million colours
Colour Gamut
76% (CIE 1931), 91% (CIE 1976), 99% sRGB
Input Connectors
2xHDMI, 2xMHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
56.9 cm x 20.5 cm x 39.8 cm
6.5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, NFPA 99
Display Type
Energy Class
Class B
41 kWh
Diagonal Size
25"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
56 - 86 Hz
Horizontal Refresh Rate
30 - 113 kHz
Video Bandwidth
241.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, stand lock, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, Factory Calibration, High Bit Rate 2 (HBR2), Transition Minimised Differential Signaling (TMDS) technology, backlight dimming control, 99% sRGB colour gamut
56.9 cm x 20.5 cm x 39.8 cm - with stand
6.5 kg
USB 3.0 upstream , 5 x USB 3.0 downstream , DisplayPort , Mini DisplayPort , 2 x MHL / HDMI , DisplayPort output (MST) , Audio line-out
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
Stand, cable management cover
1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
28 W
Power Consumption (Typical)
87 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 56.9 cm - depth: 20.5 cm - height: 39.8 cm - weight: 6.5 kg , Without stand - width: 56.9 cm - depth: 4.64 cm - height: 33.87 cm - weight: 4.4 kg
Sustainability Information
ENERGY STAR Certified
10 - 80% (non-condensing)
B15X C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
