Dell Ultrasharp U2417H 23.8" 1920x1080 6ms HDMI DisplayPort IPS LED Monitor
Quicklinx: DG0NWS00 Mfr#: 210-AHJW
The Dell UltraSharp 24 InfinityEdge monitor U2417H takes your view to the edge with less black borders. Multiple adjustability options allow you to tilt, pivot, swivel and adjust the height of the monitor to best fit the way you work.
  • Optimize your view
    Feast your eyes on the thin borders all four sides of a monitor. Dell's InfinityEdge borders, which provide the bezel width and inactive space, create an almost seamless viewing experience.
  • Stunning at every angle
    Colors remain consistent across an ultrawide viewing angle, guaranteeing a dazzling display no matter how you view it.
  • Vividly clear
    Immerse yourself in cohesive multi-monitor view with super thin borders and thinbezel width between two displays on all sides.
  • Unmatched versatility
    Enjoy full adjustability to pivot, tilt, and swivel your monitor to the position and height you desire. And with HDMI, DP, mini-DP, USB 3.0, and audio line-out ports, connecting to all your peripherals at once is both easy and convenient.
Display Type
Energy Class
Class A
Diagonal Size
23.8"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Response Time
6 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare, 3H Hard Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
Game mode, Cinema Mode, 99% sRGB colour gamut, integrated cable management, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass, Infinity Edge display
53.76 cm x 18.8 cm x 35.53 cm - with stand
5.31 kg
Bundled with
3-Years Advanced Exchange Warranty
MHL / HDMI , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
Display Position Adjustments
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, 1 USB 3.0 charging port
Stand, cable management cover
1 x SuperSpeed USB cable - 1.8 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
Plug and Play, DDC/CI, RoHS
Security Slot Type
Kensington security slot
19 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.76 cm - depth: 18.8 cm - height: 35.53 cm - weight: 5.31 kg , Without stand - width: 48.53 cm - depth: 4.52 cm - height: 31.43 cm - weight: 3.18 kg
Environmental Standards
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
