Dell UltraSharp U2414H 23.8" 1920x1080 8ms HDMI DisplayPort USB LED Monitor
Quicklinx: B4KDWS00 Mfr#: 210-ADUJ
See your work in its best light on the Dell UltraSharp 24 Monitor - U2414H. Its upscale design features an amazingly thin 6.05mm border around a 23.8" Full HD display that delivers impeccable images.
With this incredible clarity across an ultra-wide 178-degree viewing angle comes the ability to pivot left-and right up to 90 degrees, so you can create a multiple screen arrangement with near-continual imagery between two or more monitors.
  • World's thinnest border
    Create a multiple screen arrangement with near-continual imagery between multi- monitors via the DisplayPort 1.2 (MST) connectivity port.
  • Convenient connectivity
    Bring your compatible mobile phones and tablets to life on a large screen with 2 HDMI (MHL) ports. Connect to projectors or other compatible devices through DisplayPort and mini-DisplayPort connectivity.
  • Fast charging
    A high-current USB 3.0 supplies twice the power for charging and powering compatible USB devices.
Dell UltraSharp U2414H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Power Consumption (On mode)
16 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.8 million colours
Colour Gamut
72% (CIE 1931), 85% (CIE 1976), 96% sRGB (CIE 1931)
Input Connectors
2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.91 cm x 18.5 cm x 35.58 cm
5.76 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, WEEE, NFPA 99, ERP, EuP, China Energy Label, EDID compatible
3-year warranty
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Display Type
Energy Class
Class A+
24 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, stand lock, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, High Bit Rate 2 (HBR2), Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass
53.91 cm x 18.5 cm x 35.58 cm - with stand
5.76 kg
2 x MHL / HDMI , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-6.5/+22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
Cable management cover
1 x SuperSpeed USB cable - USB Type A to B , 1 x Mini DisplayPort-DisplayPort cable - miniDisplayPort to DisplayPort
Security Slot Type
Kensington security slot
Input Voltage
16 W
Power Consumption (Typical)
16 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.91 cm - depth: 18.5 cm - height: 35.58 cm - weight: 5.46 kg , Without stand - width: 53.91 cm - depth: 4.56 cm - height: 32.11 cm - weight: 3.61 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
Accessories (3)
B4KD StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
B4KD StarTech.com Dual Monitor Stand In Stock £91.00
B4KD StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
Other bundles (1)
B4KD C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
