Your basket is empty
Dell UltraSharp U2414H 23.8" 1920x1080 8ms HDMI DisplayPort USB LED Monitor
Quicklinx: B4KDWS00 Mfr#: 210-ADUJ
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: None
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
12 in stock
£173.08 ex VAT
£207.69 inc VAT
Express delivery Order within the next 8 hours for delivery tomorrow
See your work in its best light on the Dell UltraSharp 24 Monitor - U2414H. Its upscale design features an amazingly thin 6.05mm border around a 23.8" Full HD display that delivers impeccable images.
With this incredible clarity across an ultra-wide 178-degree viewing angle comes the ability to pivot left-and right up to 90 degrees, so you can create a multiple screen arrangement with near-continual imagery between two or more monitors.
Dell UltraSharp U2414H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
16 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms
Colour Support
16.8 million colours
Input Connectors
DisplayPort, Mini DisplayPort, 2 x MHL
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
53.91 cm x 18.5 cm x 35.58 cm
5.46 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, NFPA 99, TCO Displays
Display Type
Energy Class
Class A+
26 kWh
16 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Overdrive technology, 72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, LED edgelight system, stand lock, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, 96% sRGB (CIE 1931) colour gamut, Mercury free, High Bit Rate 2 (HBR2), arsenic-free glass
53.91 cm x 18.5 cm x 35.58 cm - with stand
5.46 kg
2 x MHL / HDMI , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-out
Mechanical
Tilt Angle
-6.5/+22
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, Dell Soundbar mounting slots
Stand, cable management cover
1 x SuperSpeed USB cable , 1 x Mini DisplayPort-DisplayPort cable
United Kingdom
Power Supply
Internal
74 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.91 cm - depth: 18.5 cm - height: 35.58 cm - weight: 5.46 kg , Without stand - width: 53.91 cm - depth: 4.56 cm - height: 32.11 cm - weight: 3.61 kg
ENERGY STAR Certified
10 - 80% (non-condensing)
B4KD C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B4KD C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.76
B4KD C2G 5m Select High Speed HDMI with Ethernet In Stock £15.70
B4KD C2G 10m Select High Speed HDMI with Ethernet In Stock £30.15
B4KD C2G 15m Select High Speed HDMI with Ethernet In Stock £40.84
B4KD C2G Pro HDMI to VGA Converter In Stock £46.35
Diagonal Size: 24in
Response Time: 8ms
Speakers: None
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Dell
Price Range Ex VAT: 150 - 300
