Dell UltraSharp U2413 24" 1920x1200 6ms DVI-D HDMI DisplayPort IPS LED Monitor
Quicklinx: 8PWWWS00 Mfr#: 860-10202
Experience the technology with the Dell UltraSharp U2413 24" high-performance monitor for consistent colors right out of the box. U2413 with PremierColor comes factory color calibrated to support 99% AdobeRGB which enables brilliant and accurate color hues and saturation. Six axis color control enables further user customization, professional color critical work.
  • Remarkable screen quality
    Count on consistent, calibrated hues with PremierColor, WQHD, up to 1920 x 1200 resolution and a 120% color gamut.
  • Stunning color precision and performance
  • Superb user experience
    Convenience is at your fingertips with multiple connectivity ports, including USB 3.0, DisplayPort, mini-DisplayPort, DVI-D (HDCP) and HDMI.
  • Consistent, accurate hues
    It experiences stunning color precision right out of the box with factory-color calibration.
  • Industry color standards
    Meet professional design standards with 99% AdobeRGB and 100% sRGB at a deltaE of less than 2.
  • High color gamut and depth
    A 120% color gamut and 1.07 billion colors helps enable smooth gradation of color and razor sharp details.
  • Flexible viewing
    Adjust the monitor to your most comfortable setting with tilt, swivel, pivot and height adjustability features.
  • Power management features
    Dim your monitor or put it into sleep mode with dynamic dimming or PowerNap to help save energy.
Dell UltraSharp U2413 - LED monitor - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class C
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
40 W
Card reader, USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB, 120% (CIE 1976), 99% Adobe RGB
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
55.6 cm x 20.05 cm x 41.59 cm
7.32 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
3-year warranty
Display Type
Energy Class
Class C
59 kWh
Diagonal Size
24"
Built-in Devices
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, PremierColor technology, PowerNap
55.6 cm x 20.05 cm x 41.59 cm - with stand
7.32 kg
DVI-D (HDCP) , DisplayPort , Mini DisplayPort , HDMI , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out
Mechanical
VESA Mounting Interface
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x DVI cable , 1 x DisplayPort cable , 1 x USB cable
United Kingdom
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
40 W
Power Consumption (Typical)
60 Watt
On / Off Switch
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 55.6 cm - depth: 20.05 cm - height: 41.59 cm - weight: 7.32 kg , Without stand - width: 55.6 cm - depth: 6.71 cm - height: 36.16 cm - weight: 5.01 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - express exchange - 3 years - response time: next business day
10 - 80% (non-condensing)
8PWW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
