Dell UltraSharp U2412M 24" 1920x1200 8ms VGA DVI-D DisplayPort IPS LED Monitor
Quicklinx: DKJ8WS00 Mfr#: U2412MWH-WHITE
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 8ms
Interfaces: DisplayPort, DVI, VGA (HD-15)
More than 50 in stock
£138.62 ex VAT
£166.34 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
Dell UltraSharp U2412M - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Image Colour Disclaimer
The displayed product image may be a different colour
55.6 cm x 18.03 cm x 39.85 cm
5.73 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, DDC/CI, EDID compatible
Display Type
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 61 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Overdrive technology, 72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system, PowerNap, Dynamic Dimming, stand lock, Energy Saver, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass
55.6 cm x 18.03 cm x 39.85 cm - with stand
5.73 kg
DVI-D (HDCP) , DisplayPort , VGA , 4 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Tilt Angle
-4/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
1 x DVI cable , 1 x USB cable , 1 x VGA cable
Security Slot Type
Kensington security slot
29 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, PowerNap
Dimensions & Weight Details
Without stand - width: 55.6 cm - depth: 6.49 cm - height: 36.16 cm - weight: 3.97 kg , With stand - width: 55.6 cm - depth: 18.03 cm - height: 39.85 cm - weight: 5.73 kg
TCO Certified
ENERGY STAR Certified
10 - 80% (non-condensing)
Dell UltraSharp U2412M 24 Bundle deal on Dell UltraSharp U2412M 24" 1920x1200 8ms VGA DVI-D DisplayPort IPS LED Monitor
£237.79
Diagonal Size: 24in
Response Time: 8ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 100 - 150
