Dell UltraSharp U2412M 24" 1920x1200 8ms VGA DVI-D DisplayPort IPS LED Monitor
Quicklinx: DKJ8WS00 Mfr#: U2412MWH-WHITE
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 8ms
Interfaces: DisplayPort, DVI, VGA (HD-15)
34 in stock
£159.22 ex VAT
£191.06 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
Display Type
Energy Class
Class C
Energy Consumption per Year
55 kWh
Power Consumption (On mode)
38 W
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 61 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare, 3H Hard Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Overdrive technology, 72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system, PowerNap, Dynamic Dimming, stand lock, Energy Saver, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass
White
Image Colour Disclaimer
The displayed product image may be a different colour
55.6 cm x 18.03 cm x 39.85 cm - with stand
5.73 kg
DVI-D (HDCP) , DisplayPort , VGA , 4 x USB 2.0 downstream , USB 2.0 upstream
Mechanical
Display Position Adjustments
Tilt Angle
-4/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
1 x DVI cable , 1 x USB cable , 1 x VGA cable
Plug and Play, DDC/CI, EDID compatible
Security Slot Type
Kensington security slot
29 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, PowerNap
Dimensions & Weight Details
Without stand - width: 55.6 cm - depth: 6.49 cm - height: 36.16 cm - weight: 3.97 kg , With stand - width: 55.6 cm - depth: 18.03 cm - height: 39.85 cm - weight: 5.73 kg
Environmental Standards
ENERGY STAR Certified
10 - 80% (non-condensing)
Dell UltraSharp U2412M 24 Bundle deal on Dell UltraSharp U2412M 24" 1920x1200 8ms VGA DVI-D DisplayPort IPS LED Monitor
£258.39
Diagonal Size: 24in
Response Time: 8ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 150 - 300
