Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
- Dell UltraSharp U2412M - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 82% (CIE 1976)
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Silver
- 55.6 cm x 18 cm x 51.4 cm
- 6.2 kg
- Localisation
- Israel
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 8 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, colour temperature
- UltraSharp, HDCP
- Silver
- 55.6 cm x 18 cm x 51.4 cm - with stand
- 6.2 kg
- VGA , DVI-D , DisplayPort , USB
Mechanical
- Tilt Angle
- -4/+21
- Included Accessories
- Stand
- Localisation
- Israel
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 38 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years - pick-up and return
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
