Dell UltraSharp U2412M 24'' 1920x1200 VGA DVI-D Black Monitor
Quicklinx: 8M2XWS00 Mfr#: 860-10150
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 8ms
Interfaces: DisplayPort, DVI, VGA (HD-15)
More than 50 in stock
£159.22 ex VAT
£191.06 inc VAT
Great performance, no matter how you look at it
Enjoy widescreen performance, any way you want it. With a 24"(61 cm) 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
  • Powerful: Experience IPS technology, featuring a wide viewing angle with high-quality colour representation for a peerless viewing experience.
  • Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
  • Customizable: Change your energy usage settings, text brightness and colour temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel
Display Type
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
8 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare, 3H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast
UltraSharp, HDCP, 82% (CIE 1976) colour gamut
55.6 cm x 18 cm x 51.4 cm - with stand
VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream
Mechanical
Display Position Adjustments
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable, integrated cable management
Stand
1 x DVI cable , 1 x VGA cable , 1 x USB cable
Compatible with Windows 7
United Kingdom
Security Slot Type
Kensington security slot
38 Watt
Dimensions & Weight Details
Without stand - width: 55.6 cm - depth: 6.5 cm - height: 36.2 cm - weight: 4 kg , With stand - width: 55.6 cm - depth: 18 cm - height: 51.4 cm
Environmental Standards
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Dell UltraSharp U2412M 24'' 1920x1200 VGA DVI-D Black Monitor Bundle deal on Dell UltraSharp U2412M 24'' 1920x1200 VGA DVI-D Black Monitor
£258.39
8M2X C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £23.18
8M2X C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £25.32
8M2X C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
8M2X C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.60
8M2X C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £21.26
8M2X C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £16.29
Diagonal Size: 24in
Response Time: 8ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 150 - 300
