Great performance, no matter how you look at it
Enjoy widescreen performance, any way you want it. With a 24"(61 cm) 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
- Powerful: Experience IPS technology, featuring a wide viewing angle with high-quality colour representation for a peerless viewing experience.
- Flexible: Pick the view that works best for you with an almost unlimited range of tilt, swivel, pivot and height adjustments.
- Customizable: Change your energy usage settings, text brightness and colour temperature with the touch of a button to help conserve energy with this eco-designed arsenic-free and mercury-free panel
- Dell UltraSharp U2412M - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Black
- 55.6 cm x 18 cm x 51.4 cm
- Localisation
- United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 24"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 8 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast
- UltraSharp, HDCP, 82% (CIE 1976) colour gamut
- Black
- 55.6 cm x 18 cm x 51.4 cm - with stand
- VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable, integrated cable management
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable , 1 x VGA cable , 1 x USB cable
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 38 Watt
- Dimensions & Weight Details
- Without stand - width: 55.6 cm - depth: 6.5 cm - height: 36.2 cm - weight: 4 kg , With stand - width: 55.6 cm - depth: 18 cm - height: 51.4 cm
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- TCO Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.17 | in stock |
£250.66
C2G HDMI to DisplayPort Adapter Converter | In Stock | £36.51 |
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £22.06 |
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £24.09 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £8.17 |
C2G 10m DisplayPort Cable with Latches M/M – Black | In Stock | £22.77 |
C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black | In Stock | £15.82 |
C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black | In Stock | £20.25 |
C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black | In Stock | £15.51 |
